Equivalent mount kit of AP-MNT-C1 in 500 series
This thread has been viewed 32 times
  • 1.  Equivalent mount kit of AP-MNT-C1 in 500 series
    Posted May 18, 2021 05:01 AM
    We currently use AP 300 series along with AP-MNT-C1 mount kit which is rail mount kit. We are now looking for 500 series AP, can anyone confirm which will be the equivalent mount kit. I could see Type A,B and C are available in rail mount but which one will be equivalent or similar to AP-MNT-C1. thanks in advance
    Daniel Dsouza
  • 2.  RE: Equivalent mount kit of AP-MNT-C1 in 500 series
    MVP GURU
    Posted May 18, 2021 06:35 AM
    See this link: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=31544
    The Aruba AP-MNT-MP10 Indoor Access Point Mount Kits.pdf will tell you what you need to know for each mount type available from Aruba.
    Dustin Burns
    Senior Mobility and Access Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: Equivalent mount kit of AP-MNT-C1 in 500 series
    Posted May 20, 2021 12:49 PM
    I mount hundreds of APs on grid ceilings at work, but I'm scared to run cable and do it at home. Punching a hole from the attic seems awful permanent. Drilling screws from the mounting bracket seems okay, once. What about when I upgrade the AP? The new bracket will likely leave holes where the screws were. What about when I sell the house? If I take the AP down there will now be a random hole.
    Any thoughts?
    kabosu coin
    Gladyce Rohan
  • 4.  RE: Equivalent mount kit of AP-MNT-C1 in 500 series
    MVP GURU
    Posted May 20, 2021 05:15 PM
    Plaster or spackle repair kit? :) Either way you need to make a hole for the cable no?
    Dustin Burns
