Erorr Code 215 TLS Session Erorr - Clearpass OnBoard
  • 1.  Erorr Code 215 TLS Session Erorr - Clearpass OnBoard
    Posted Mar 06, 2017 03:56 AM
    Hi All,
    I'm trying to configure OnBoard for first time with Local User.
    I got the Message below :
    Kindly need your advice
    Thank you
  • 2.  RE: Erorr Code 215 TLS Session Erorr - Clearpass OnBoard
    Posted Mar 07, 2017 03:37 AM
    This log message indicates that the OCSP certificate validation is not working properly. You should fix this in the OCSP settings in the Onboard CA (so it will add a reachable OCSP URL to the client certificates), or for now create a custom [EAP-TLS] Authentication Method that has an overridden OCSP URL; or switch off OCSP validation. This screenshot shows the OCSP override as an example:
    In here you can also disable Verify Certificate, to check that it is indeed the OCSP. The OCSP URL can be found in the CA list.
