ERR_CERT_START_TIME_VALID_IN_FUTURE Isakmp Error with RAP5s
  • 1.  ERR_CERT_START_TIME_VALID_IN_FUTURE Isakmp Error with RAP5s
    Posted Jan 19, 2012 01:24 AM
    I have a controller running 6.1.2.6, and a few RAP5s connected to it.
    For some reason, some of the RAP5s refuse to connect, and the security debug logs show that ISAKMP is failing with this message:
    I'll be opening a TAC ticket for this, but has anyone else seen this before?
  • 2.  RE: ERR_CERT_START_TIME_VALID_IN_FUTURE Isakmp Error with RAP5s
    Posted Jan 19, 2012 03:33 AM
    Not seen it, but my first theory would be some sort problem with a custom or signed certificate that you might have installed on the server? Are you using the default or one that you installed? If you installed one, what dates are embedded in it?
    If you didn't install one, I'd be checking the clock on my controller first, setting it if it was not accurate and trying again.
    If that failed too, log a TAC case probably. What version is it? Never seen that on any main train I've used.
  • 3.  RE: ERR_CERT_START_TIME_VALID_IN_FUTURE Isakmp Error with RAP5s
    Posted Jan 19, 2012 03:34 AM
    Sorry about the typo, I mean "certificate you installed on the controller", not server.
  • 4.  RE: ERR_CERT_START_TIME_VALID_IN_FUTURE Isakmp Error with RAP5s
    Posted Jan 19, 2012 03:37 AM
    Figured this one out... the clock on the controller was off, and so the certificate the RAP5 was using was dated in the future as far as the controller was concerned.
    After adjusting the clock to use the correct time, the RAP5s all immediately started connecting to the controller and everything was happy.
  • 5.  RE: ERR_CERT_START_TIME_VALID_IN_FUTURE Isakmp Error with RAP5s
    Posted Jan 19, 2012 03:54 AM
    Ahhh, my second guess was right! Glad you got it going. Have fun.
