Error 404 on Clearpass Web Administration
  • 1.  Error 404 on Clearpass Web Administration
    Posted Jun 12, 2017 01:39 PM
    Mi client has a Clearpass Policy Manager 6.6.0.81015 on production environment for about 3 months so far, all working right.
    Today in the morning my client tried to connect to the web server and the following error shows:
    Estado HTTP 404 - /tips/welcome.action
    type Informe de estado
    mensaje /tips/welcome.action
    descripción El recurso requerido no está disponible.
    Apache Tomcat
    We have verified that the clients can still authenticate as always.
    I have tried using the command: service restart cpass-admin-server (Log attached) but the web server won't work.
    We are going to try a reboot of the Clearpass VM on the afternoon after 6 pm when all the wireless users leave, but I wanted to know if some has any extra command or information to check before proceeding, or if someone got a similar problem.
    Best Regards
    Luis Regis
    Attachment(s)
  • 2.  RE: Error 404 on Clearpass Web Administration
    Posted Jun 13, 2017 05:02 AM
    Could it be that you locked down application level access the the ClearPass Admin UI?
    That is configured: Administration » Server Manager » Server Configuration > <your clearpass node> .> Network > Application Access control.
    If your deployment is locked down (which is good) and administrators come in from an unauthorized IP address (maybe the network was renumbered), it could be that you see this 404 error.
    If you still have access to the console (appadmin), you can reset the application access control from there:
    [appadmin@cppm1-pub]# system apps-access-reset
    Policy Manager application access is restored
    Stopping httpd:                                            [  OK  ]
    Starting httpd:                                            [  OK  ]
    After that, you should have access again.
