last person joined: 7 hours ago
Error accessing clearpass polciy manager application.
  • 1.  Error accessing clearpass polciy manager application.
    Posted Apr 20, 2014 08:58 PM
    I already configured controller and clearpass server and see to it that i have a authentication successfull in between.
    Now as i test the server, after connecting to the ssid associated to clearpass i always get redirected to a page showing
    Error accessing clearpass policy manager application, then in 5 seconds i will be on the clearpass policy manager login page.
    Please help. Thanks
  • 2.  RE: Error accessing clearpass polciy manager application.
    Posted Apr 20, 2014 10:38 PM
    That means your redirect is setup wrong. Double check the URL
  • 3.  RE: Error accessing clearpass polciy manager application.
    Posted Apr 20, 2014 10:50 PM
    Thanks for the reply.
    Does clearpass have a default redirect url page which i can use for now. Im new to clearpass. Thanks
  • 4.  RE: Error accessing clearpass polciy manager application.
    Posted May 06, 2014 07:09 AM
    not really, you might try /agent/portal/ but that is more for onguard these days.
    easiest for to setup a simple page via guest:  Home » Configuration » Web Logins
