Error after upgrading to Aruba 8.0
  • 1.  Error after upgrading to Aruba 8.0
    Posted Feb 21, 2019 10:17 AM
    We are in the process of upgrading our Aruba OS from 6.4 to 8.3 and we moved about 10% over for now. I have noticed that we get the following message:
    An internal system error has occurred at file sapd_msg.c function sapd_pwr_report_timer_handler line 9834 error sap
    The controller shows the AP down but you can still ping it. It's only happening to the AP-105s. The APs 215,275,315 and 364 are not having this problem. The only way to fix this problem is to reboot the AP. I was wondering if the anybody knows what this error means?
  • 2.  RE: Error after upgrading to Aruba 8.0
    Posted Feb 22, 2019 11:02 AM
    Does anybody out there have AP-105s connected on their network running 8.3.3?
  • 3.  RE: Error after upgrading to Aruba 8.0
    Posted Feb 22, 2019 11:27 AM
    What version of 8.3 is this?  A similar bug is fixed in 8.3.0.4 (and 8.3.0.6 is out right now - recommended).
  • 4.  RE: Error after upgrading to Aruba 8.0
    Posted Feb 25, 2019 01:38 PM
    We're running 8.3.0.3
  • 5.  RE: Error after upgrading to Aruba 8.0
    Posted Feb 12, 2020 03:41 AM
    from version 8.4 above or from 8.5 the default credentials are admin/serial number
    try to reset the AP and see if that helps
