Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
  • 1.  Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 06:21 AM
    After upgarde Aruba 3400 (6.4.4.5) I have some access points can't join controller
    x.x.x = Master
    y.y.y = local
    i try to clearos+Factory_reset+new provision but still can't join controller, You can help me ?
    Log error
    eth0  RGMII  100Mbps  full duplex
    asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x.x for heartbeat tunnel.
    Enet:0 port:0 down
    Enet:0 port0 up
    asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from y.y.y.y for heartbeat tunnel.
  • 2.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 06:25 AM
    What model access points?
  • 3.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 06:32 AM
    Dear cjoseph
    Aruba AP115  (APIN0115)
  • 4.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 06:34 AM
    Do you have enough ip addresses?  That error could occur if the AP has a duplicate ip address.
  • 5.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 06:39 AM
    no duplicate ip address. before upgrade ap can join to controller, after upgrde  ap can't join and alert error log.
  • 6.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 06:45 AM
    Can I ask why you are upgrading?
  • 7.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 06:53 AM
    Customer request, I dont know why.
  • 8.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 06:55 AM
    The error message only indicates that there is a communication problem between the AP and the controller.  It could be a range of things.  How many access points does that controller have?
  • 9.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 06:59 AM
    - 61 AP
    - 3 AP fail
    -License support 64
  • 10.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 07:01 AM
    Type "show log system 50" on the controller to see if there is a relevant message.
  • 11.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 10:06 AM
    Daer cjoseph
    Mar 28 01:26:02 :311004:  <WARN> |AP test@10.1.50.122 sapd|  Missed 8 heartbeats; rebootstrapping
    Mar 28 01:30:43 :311004:  <WARN> |AP test@10.1.50.122 sapd|  Missed 8 heartbeats; rebootstrapping
    Mar 28 01:41:06 :311004:  <WARN> |AP test@10.1.50.122 sapd|  Missed 8 heartbeats; rebootstrapping
    Mar 28 01:45:19 :311004:  <WARN> |AP test@10.1.50.122 sapd|  Missed 8 heartbeats; rebootstrapping
    Mar 28 02:17:32 :311004:  <WARN> |AP test@10.1.50.122 sapd|  Missed 8 heartbeats; rebootstrapping
    Mar 28 02:24:12 :311004:  <WARN> |AP test@10.1.50.122 sapd|  Missed 8 heartbeats; rebootstrapping
    Mar 28 02:53:43 :311004:  <WARN> |AP test@10.1.50.122 sapd|  Missed 8 heartbeats; rebootstrapping
    Mar 28 04:01:10 :311004:  <WARN> |AP test@10.1.50.122 sapd|  Missed 8 heartbeats; rebootstrapping
    Mar 28 04:05:06 :311004:  <WARN> |AP test@10.1.50.122 sapd|  Missed 8 heartbeats; rebootstrapping
    Mar 28 04:18:26 :311004:  <WARN> |AP test@10.1.50.122 sapd|  Missed 8 heartbeats; rebootstrapping
    Mar 28 04:21:05 :305061:  <WARN> |stm|  sapm_gap_rcv_master_update: Received Resync msg with Resync_all 0 Num Resync APs 1
    Mar 28 04:21:05 :305061:  <WARN> |stm|  sapm_gap_process_master_ap_resync_req: Process Resync req - AP test with MAC 18:64:72:c2:bb:64 added to resync_pending
    Mar 28 04:21:05 :305061:  <WARN> |stm|  sapm_gap_lms_cleanup_ap_sync_data: Adding Resync pending AP test to update list
    Mar 28 20:51:16 :305061:  <WARN> |stm|  sapm_gap_rcv_master_update: Received Resync msg with Resync_all 0 Num Resync APs 1
    Mar 28 20:51:16 :305061:  <WARN> |stm|  sapm_gap_process_master_ap_resync_req: Process Resync req - test with MAC 18:64:72:c2:bb:64 added to resync_pending
    Mar 28 20:51:16 :305061:  <WARN> |stm|  sapm_gap_lms_cleanup_ap_sync_data: Adding Resync pending AP test to update list
  • 12.  RE: Error asap_gre_ipv4_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from x.x.x for heartbeat tunnel.
    Posted Mar 28, 2016 10:08 AM
    Trace the path between those access points and the controller and find out what could be causing congestion.  I saw that your access points are only on 10/100 ports.  If everything (including the controller) is on 10/100 ports, that might not be enough to sustain the bandwidth.  You might need a gigabit ethernet port.
