error converting rap155
  • 1.  error converting rap155
    Posted Jan 23, 2014 01:58 PM
    Hi Guys, im trying to convert a new rap155 (being using rap5s before) im getting the attached error stating image verify failed..
    I then get an output that is also attached.
    Any one have any idea whats causing the issue?
    Any help here is greatly appriciated!
    Regards
    Anthony
    Attachment(s)
    txt
    aruba155.txt   23 KB 1 version
  • 2.  RE: error converting rap155
    Posted Jan 23, 2014 02:30 PM
    What AOS are you using ? Do you have AOS 6.3 installed ?
  • 3.  RE: error converting rap155
    Posted Jan 23, 2014 08:00 PM
    MINIMUM SOFTwARE VERSIONS
    ArubaOS™
    6.3.0.0
    Aruba
    Instant
    3.3.0.1
     This is why Victor ask you about the firmware
    Cheers
    Carlos
  • 4.  RE: error converting rap155
    Posted Jan 24, 2014 03:37 AM
    Hi Guys,
    The 3200 is on 6.2.1.4
    The RAP155 is on 6.3.1.1-4.0.0.1_41049
    So im guessing the controller is out of date already?
    Anthony
  • 5.  RE: error converting rap155
    Posted Jan 24, 2014 04:55 AM
    Your 3200 needs to be on AOS6.3 in order to support rap155
    http://www.arubanetworks.com/pdf/products/DS_RAP-155.pdf
  • 6.  RE: error converting rap155
    Posted Jan 24, 2014 06:22 AM
    Is this a 3200XM or just regular 3200?
    Tim Cappalli | ACCP / ACMP / CCNA
    Network Engineer | Brandeis University
    cappalli@brandeis.edu | (617) 701-7149
  • 7.  RE: error converting rap155
    Posted Jan 27, 2014 05:43 AM
    Hi Guys,
    Thanks for your help on this, It looks like im going to have to get the aruba controller upgraded to 6.3 which leads me on to my next few questions:
    If I upgrade the secondary partition to 6.3 and something goes wrong and im not able to connect back to the web interface, is it the case of connecting to the console to use/swap back to the primary partition or is there a button sequence on the controller (for a less technical) person to use?
    We do have an aruba partner on hand IF we have any problems but as we have just had this new controller installed in november we feel they didnt upgrade maybe to force our hands a little...
    Has anybody had any issues upgraded from 6.2 to 6.3 yet?
    Any help will be greatly appreciated!
    Anthony
  • 8.  RE: error converting rap155
  • 9.  RE: error converting rap155
    Posted Jan 27, 2014 06:29 AM
    @Arjwalker wrote:
    Hi Guys,
    Anthony
    ArubaOS 6.3.1.2 Went GA (General Availability) Friday:  http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Recent-AOS-Firmware-Releases/m-p/135437#M28904
