Error DUR read-only account
  • 1.  Error DUR read-only account
    Posted Sep 20, 2018 04:31 AM
    I'm trying to get DUR working on a 2930F switch. I get this error:
    dca: 8021X Deauthenticating client 5C260A7BB28C on
    port 1, downloaded user role DUR_OMO_MANAGED_1... is not valid as
    Invalid cppm username/password.
    But i know for a fact that the username/password is correct.
    The 2930F are managed by aruba central though. I tried logging in with the credentials on the CPPM and it works. Also there is HTTPS access to the CPPM from the aruba switch.
    Anybody else got this problem? I opened a TAC Case.
    With kind regards,
    Martijn
  • 2.  RE: Error DUR read-only account
    Posted Sep 20, 2018 08:54 AM
    Could you share the versions you are using, both on the switch and on ClearPass?
    Also the switch config snippet would be helpful.
    Have you followed the instructions in Wired Policy Guide?: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=28803
  • 3.  RE: Error DUR read-only account
    Posted Sep 20, 2018 09:04 AM
    Seems that the configuration template of aruba central is not forwarding the password of the DUR user. I can’t use cli snip because my OS version of the switch 16.05.
    Workaround is to configure alle classes/policies and user roles static on the switch for now. I’m waiting if they find a solution for this.
    Met vriendelijke groet,
    Martijn Gruijters
    Senior Solution Consultant
    [Logo_4IP_Solutions_connectivity_RGB_Tagline_150dpi - Copy]
    4IP Solutions
    Eindhoven ● Amsterdam
    Mahatma Gandhilaan 2
    5653 ML Eindhoven
    t +31 (0)88 428 48 88
    m +31 (0)65 185 71 88
    e martijn.gruijters@4ip.nl
    w www.4ip.nl
    [cid:image002.png@01D28CEF.75FAD190][cid:image003.png@01D28CEF.75FAD190]
  • 4.  RE: Error DUR read-only account
    Posted Sep 20, 2018 10:57 AM
    Yes, definitely work with TAC.
    Do you see any error reported in the Audit Trail of Central related to the template?
  • 5.  RE: Error DUR read-only account
    Posted Mar 06, 2019 12:02 PM
    Please add this to all ZTP templates using Clearpass certificate downloads. Adds an "insurance policy" to induce a retry when the initial certificate download fails.
    crypto ca-download usage clearpass retry <secs>”
  • 6.  RE: Error DUR read-only account
    Posted Aug 28, 2019 09:04 PM
    Yeah i have also come across this one, TAC case raised.
    Did you happen to raise a TAC case and get an answer as to how to fix?
  • 7.  RE: Error DUR read-only account
    Posted Feb 18, 2020 08:53 AM
    Did you get any respone on this problem?
    I have the exact same issue now. I have even tried to remove the switch from central and add the username and password manually with no luck.
  • 8.  RE: Error DUR read-only account
    Posted Feb 25, 2020 04:56 PM
    What i found is if using Aruba Central to push configuration down to the switches  you need to add the following command in your Template.
    include-credentials clearpass-key
    Otherwise the key is not passed from Central to the Switch.
    Example:
    %_sys_template_header%
    hostname "%_sys_hostname%"
    %_sys_module_command%
    no cwmp enable
    include-credentials
    password manager user-name "manager" sha1 "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
    radius-server host 192.168.1.1 key "radiuskey"
    radius-server host 192.168.1.1 dyn-authorization
    radius-server host 192.168.1.1 time-window plus-or-minus-time-window
    radius-server host 192.168.1.1 time-window 30
    radius-server host "clearpass.fred.co.nz" key "radiuskey"
    radius-server host "clearpass.fred.co.nz" clearpass
    radius-server cppm identity "MY_apiadmin" key "apiuserpass"
    timesync ntp
  • 9.  RE: Error DUR read-only account
    Posted Feb 26, 2020 05:13 AM
    That did the trick!
