Error in SNMP polling: Timeout(thin_ap_status)
  • 1.  Error in SNMP polling: Timeout(thin_ap_status)
    Posted Oct 31, 2015 07:38 AM
    dear sir
         Recently often MY Airwave event log appear error in SNMP polling,just like the below list
    Sat Oct 31 17:43:28 2015 System Device Aruba 7205 Aruba-7205-IACP-Master Down 107 Top > IACP_Aruba7210 Access Points
    Sat Oct 31 17:43:06 2015 System Device Aruba 7205 Aruba-7205-IACP-Master Error in SNMP polling: Timeout(aruba_local_controller_discovery) 107 Top > IACP_Aruba7210 Access Points
    Sat Oct 31 17:42:39 2015 System Device Aruba 7205 Aruba-7205-IACP-Master Error in SNMP polling: Timeout(device_resources) 107 Top > IACP_Aruba7210 Access Points
    Sat Oct 31 17:41:49 2015 System Device Aruba 7205 Aruba-7205-IACP-Master Error in SNMP polling: Timeout(controller_role) 107 Top > IACP_Aruba7210 Access Points
    Sat Oct 31 17:40:49 2015 System Device Aruba 7205 Aruba-7205-IACP-Master Error in SNMP polling: Timeout(interface_bandwidth) 107 Top > IACP_Aruba7210 Access Points
    Sat Oct 31 17:40:32 2015 System Device Aruba 7205 Aruba-7205-IACP-Master Error in SNMP polling: Timeout(thin_ap_status) 107 Top > IACP_Aruba7210 Access Points
    Sat Oct 31 17:37:54 2015 System System Your license does not allow you to create or authorize additional APs/Devices
    who can tello me what causes it and how to fix, very thanks
    #7205
  • 2.  RE: Error in SNMP polling: Timeout(thin_ap_status)
    Posted Oct 31, 2015 10:27 AM
    Somehow it seems like your controller is not responding to snmp.
    It also seems like you are out of licenses.
  • 3.  RE: Error in SNMP polling: Timeout(thin_ap_status)
    Posted Nov 01, 2015 12:18 AM
    Dear Joseph
       Yes, My Arirwave is out of licensed, the purchase is underway,。so, the cause of Aruba down is AirWave sending a reboot command to the controller.,where can I find the log ?
  • 4.  RE: Error in SNMP polling: Timeout(thin_ap_status)
    Posted Nov 01, 2015 06:29 AM
    Airwave will not send a reboot command to controller if you are out of licenses.  The controller not responding to SNMP is a different issue.  Can you get into the controller and type "show version" on the commandline?
  • 5.  RE: Error in SNMP polling: Timeout(thin_ap_status)
    Posted Nov 01, 2015 09:37 PM
    dear  Joseph
             The "show version" on the commandline list just like below,why the controller had down in snmp timeout ,  how could I find the cause, very tks.
    (Aruba-7205-IACP-Master) #show version
    ArubaOS (MODEL: Aruba7205), Version 6.4.3.2
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2015, Aruba Networks, Inc.
    Compiled on 2015-06-03 at 16:33:32 PDT (build 50323) by p4build
    ROM: System Bootstrap, Version CPBoot 1.0.1.0 (build 48228)
    Built: 2015-01-22 04:53:25
    Built by: p4build@re_client_48228
    Switch uptime is 1 days 16 hours 36 minutes 28 seconds
    Reboot Cause: Kernel Panic (Intent:cause:register 12:86:0:2c)
    Supervisor Card
    Processor (XLP316 Rev B2 (Secure Boot) , 1200 MHz) with 7882M bytes of memory.
    32K bytes of non-volatile configuration memory.
    3872M bytes of Supervisor Card system flash.
  • 6.  RE: Error in SNMP polling: Timeout(thin_ap_status)
    Posted Nov 01, 2015 09:43 PM
    It says reboot cause is kernel panic. Please contact tac asap.
