Wired Intelligent Edge
Error: Interface is configured with non-default QoS profile
  • 1.  Error: Interface is configured with non-default QoS profile
    Posted Apr 13, 2015 08:02 PM
    Hi.
    When I try to put ports 22 and 23 into a channel port on my S1500, I get this error message:
    interface port-channel 0 port-channel-members add gigabitethernet 0/0/22 : Error: Interface is configured with non-default QoS profile
    interface port-channel 0 port-channel-members add gigabitethernet 0/0/23 : Error: Interface is configured with non-default QoS profile
    Has  anyone else run into ths message? Am I forgetting to do something prior to trying to creating the channel port?
    Thank you
  • 2.  RE: Error: Interface is configured with non-default QoS profile
    Posted Apr 13, 2015 11:30 PM
    Run the show interface-config gig 0/0/22 and 0/0/23 andd see if it has a different QoS profile attached , those should have the same QoS profile as the port-channel
  • 3.  RE: Error: Interface is configured with non-default QoS profile
    Posted Apr 14, 2015 07:12 AM
    Hi Victor.
    Thanks for your reply. I appreciate any help I can get.
    As far as I can see, they have the same QoS profile. Here is what I see when I run the commands that you suggested:
    (200-WLAN) (config) # show interface-config gigabitethernet 0/0/22
    gigabitethernet "0/0/22"
    Parameter Value Config De rivation
    Interface MSTP Profile default default
    Interface Rapid PVST Profile default default
    Interface GVRP Profile N/A gigabitet hernet0/0/22
    Interface Tunneled Node Profile N/A gigabitet hernet0/0/22
    Interface VOIP Profile N/A gigabitet hernet0/0/22
    Interface LLDP Profile lldp-factory-initial default
    Interface PoE Profile poe-factory-initial default
    Interface Ethernet Link Profile default default
    Interface OAM Profile N/A gigabitet hernet0/0/22
    Interface LACP Profile N/A gigabitet hernet0/0/22
    Interface QoS Profile default gigabitethernet0/0/22
    Interface Policer Profile N/A gigabitethernet0/0/22
    Interface AAA Profile N/A gigabitethernet0/0/22
    Interface Shutdown Disabled default
    Interface MTU 1514 default
    Interface Ingress ACL N/A gigabitethernet0/0/22
    Interface Egress ACL N/A gigabitethernet0/0/22
    Interface QoS Trust Mode aruba-device default
    Interface Description N/A default
    Interface Switching Profile Upstream-profile gigabitethernet0/0/22
    Interface Security Profile N/A gigabitethernet0/0/22
    Ingress Port Mirroring Profile N/A gigabitethernet0/0/22
    Egress Port Mirroring Profile N/A gigabitethernet0/0/22
    Static IGMP Multicast Router port for the VLANs 0 default
    Static MLD Multicast Router port for the VLANs 0 default
    Interface Trusted Mode Enabled default
    HSL backup interface N/A gigabitethernet0/0/22
    HSL preemption mode Off default
    HSL preemption delay 100 default
    (200-WLAN) (config) # show interface-config gigabitethernet 0/0/23
    gigabitethernet "0/0/23"
    Parameter Value Config Derivation
    Interface GVRP Profile N/A gigabitethernet0/0/23
    Interface Tunneled Node Profile N/A gigabitethernet0/0/23
    Interface VOIP Profile N/A gigabitethernet0/0/23
    Interface OAM Profile N/A gigabitethernet0/0/23
    Interface LACP Profile N/A gigabitethernet0/0/23
    Interface QoS Profile default gigabitethernet0/0/23
    Interface Policer Profile N/A gigabitethernet0/0/23
    Interface AAA Profile N/A gigabitethernet0/0/23
    Interface Ingress ACL N/A gigabitethernet0/0/23
    Interface Egress ACL N/A gigabitethernet0/0/23
    Interface Switching Profile Upstream-profile gigabitethernet0/0/23
    Interface Security Profile N/A gigabitethernet0/0/23
    Ingress Port Mirroring Profile N/A gigabitethernet0/0/23
    Egress Port Mirroring Profile N/A gigabitethernet0/0/23
    HSL backup interface N/A gigabitethernet0/0/23
  • 4.  RE: Error: Interface is configured with non-default QoS profile
    Posted Apr 14, 2015 07:31 AM
    Whats the QoS profile on the port channel group ?
  • 5.  RE: Error: Interface is configured with non-default QoS profile
    Posted Apr 14, 2015 09:34 AM
    Please find the attached screenshot of the GUI Qos Profile settings, also. Hope this helps.
    (Host) #show qos-profile
    QoS Profile List
    Name References Profile Status
    default 26 N/A
    qos-none 0 Predefined
    Total:2
  • 6.  RE: Error: Interface is configured with non-default QoS profile
    Posted Apr 14, 2015 10:28 AM
    Run the following command and try again :
    (Lab_Aruba_MAS) (config) #no interface gigabitethernet 0/0/22
    (Lab_Aruba_MAS) (config) #no interface gigabitethernet 0/0/23
  • 7.  RE: Error: Interface is configured with non-default QoS profile
    Posted Apr 14, 2015 10:44 AM
    That worked!
    Many, many thanks, Victor.
  • 8.  RE: Error: Interface is configured with non-default QoS profile
    Posted Apr 14, 2015 10:48 AM
    Glad it did , revisited one of the other posts and noticed that it had each interface had the interface derivation config attached to it.
  • 9.  RE: Error: Interface is configured with non-default QoS profile
    Posted Jun 13, 2016 07:21 PM
    I have the same issue but the solution still did not work for me.  Any help would be greatly appreciated!!
    gigabitethernet "0/0/3"
    Interface MSTP Profile Lab-BPDU-Guard default
    Interface GVRP Profile N/A gigabitethernet0/0/3
    Interface Tunneled Node Profile N/A gigabitethernet0/0/3
    Interface VOIP Profile N/A gigabitethernet0/0/3
    Interface OAM Profile N/A gigabitethernet0/0/3
    Interface LACP Profile N/A gigabitethernet0/0/3
    Interface QoS Profile default gigabitethernet0/0/3
    Interface Policer Profile N/A gigabitethernet0/0/3
    Interface AAA Profile N/A gigabitethernet0/0/3
    Interface Ingress ACL N/A gigabitethernet0/0/3
    Interface Egress ACL N/A gigabitethernet0/0/3
    Interface Switching Profile upstream_trunk gigabitethernet0/0/3
    Interface Security Profile N/A gigabitethernet0/0/3
    Ingress Port Mirroring Profile N/A gigabitethernet0/0/3
    Egress Port Mirroring Profile N/A gigabitethernet0/0/3
    HSL backup interface N/A gigabitethernet0/0/3
    gigabitethernet "0/0/1"
    Interface GVRP Profile N/A gigabitethernet0/0/1
    Interface Tunneled Node Profile N/A gigabitethernet0/0/1
    Interface VOIP Profile N/A gigabitethernet0/0/1
    Interface OAM Profile N/A gigabitethernet0/0/1
    Interface LACP Profile N/A gigabitethernet0/0/1
    Interface QoS Profile default gigabitethernet0/0/1
    Interface Policer Profile N/A gigabitethernet0/0/1
    Interface AAA Profile N/A gigabitethernet0/0/1
    Interface Ingress ACL N/A gigabitethernet0/0/1
    Interface Egress ACL N/A gigabitethernet0/0/1
    Interface Switching Profile upstream_trunk gigabitethernet0/0/1
    Interface Security Profile N/A gigabitethernet0/0/1
    Ingress Port Mirroring Profile N/A gigabitethernet0/0/1
    Egress Port Mirroring Profile N/A gigabitethernet0/0/1
    HSL backup interface N/A gigabitethernet0/0/1
    port-channel "0"
    Parameter Value
    LACP N/A
    Interface Ethernet Link Profile pc_default
    Interface Shutdown Enabled
    Interface MTU 1514
    Port channel member list N/A
    QoS Profile List
    default 4 N/A
    Total:2
    QoS Profile "default" (N/A)
    Parameter Value
    Traffic Class 0
    Drop Precedence low
    DSCP 0
    802.1p N/A
