Error Joining Clearpass to AD
  • 1.  Error Joining Clearpass to AD
    Posted Nov 29, 2017 08:04 PM
    Hi there.
    I'm getting an error while I try to join Clearpass to AD.
    Scenario:
    Clearpass hostname: cppm_enp
    IP address: 10.5.0.4
    Active directory IP: 10.5.0.10
    Domain Controller name (FQDN): PocociAD.seguridadpublica.go.cr as you can see on the following capture:Join AD 3.png
    If I go to the command line an put nslookup I get that: Join AD 4.png
    Also I have created a new entry on the DNS service for the clearpass server.
    Both servers (Clearpass and AD) ping each others.
    Then, I go to Administration-> Server Manager--> Server configuration and then to Join AD domain option and fullfil the fields as you can see on the following capture: AD Join.PNG
    As you can see the NetBios field obtain the value automatically after I write the complete Domain Controller name, then I write the password and Click Save and the process starts. And then it shows the next error: AD Join 2.PNGJust to clarify the time on both servers are synchronized.
    Thank you in advance!
  • 2.  RE: Error Joining Clearpass to AD
    Posted Nov 29, 2017 08:35 PM
    Have you tried doing an NSLOOKup from ClearPass CLI ?
    Get Outlook for iOS
  • 3.  RE: Error Joining Clearpass to AD
    Posted Nov 30, 2017 10:39 AM
    Hi Victor, yes, I have tried, look: Join AD 5.PNG
  • 4.  RE: Error Joining Clearpass to AD
    Is there a firewall between ClearPass and the domain controllers? Are the required ports allowed between them?
  • 5.  RE: Error Joining Clearpass to AD
    Posted Nov 30, 2017 10:44 AM
    Hi Tim, I have created a new rule on Windows Firewall allowing port TCP/UDP 389 and nothing happened.
  • 6.  RE: Error Joining Clearpass to AD
  • 7.  RE: Error Joining Clearpass to AD
    Posted Nov 30, 2017 11:16 AM
    Thank you Tim, I think it was necessary to disable and enable again the firewall to "apply changes". Now its joined.
    Thanks Victor too.
