Error message in logs - An internal system error has occurred at file sapd_sysctl.c
This thread has been viewed 60 times
  • 1.  Error message in logs - An internal system error has occurred at file sapd_sysctl.c
    Posted Oct 16, 2013 12:10 PM
    I'm getting the error logs filling up with these messages.
    Oct 16 12:47:02 <sapd 311020>  <ERRS> |AP BR-VAC-CTL-WAP029@172.16.55.7 sapd|  An internal system error has occurred at file sapd_sysctl.c function sapd_sysctl_write_param line 77 error Error opening /proc/sys/net/aruba_asap/aruba003/bw_share : No such file or directory.
    They are coming from all APs at one particular site.  The APs are RAPs as well.
    version - 6.2.1.3
    Should I be concerned by this?
  • 2.  RE: Error message in logs - An internal system error has occurred at file sapd_sysctl.c
    Posted Oct 16, 2013 12:42 PM
    According to the syslog message guide
    An internal system error has occurred at file [file:%s] function [function:%s] line [line:%d]
    error [error:%s].
    Description: This log indicates that we encountered an internal system error.
    Recommended Action: Contact your support provider
    Best recommendation is to contact TAC...
  • 3.  RE: Error message in logs - An internal system error has occurred at file sapd_sysctl.c
    Posted Oct 16, 2013 02:46 PM
    Ah yes, forgot to check that.  Case raised with TAC.
  • 4.  RE: Error message in logs - An internal system error has occurred at file sapd_sysctl.c
    Posted Oct 16, 2013 03:16 PM
    I'd be curious to know what the message means.
  • 5.  RE: Error message in logs - An internal system error has occurred at file sapd_sysctl.c
    Posted Oct 16, 2013 03:36 PM
    the error message contains 'bw_share' and I have bandwidth contracts for some of the ssids on those APs so I guest it has something to do with that.  I will let you know what TAC say.
  • 6.  RE: Error message in logs - An internal system error has occurred at file sapd_sysctl.c
    Posted Oct 16, 2013 03:48 PM
    I figured as much. Are you using bandwitdth contracts in split-tunnel? Just curious.
  • 7.  RE: Error message in logs - An internal system error has occurred at file sapd_sysctl.c
    Posted Oct 16, 2013 03:50 PM
    the bandwidth contracts on the tunnelled ssids.  Another ssid is bridge but no bw contract on that one.
  • 8.  RE: Error message in logs - An internal system error has occurred at file sapd_sysctl.c
    Posted Oct 29, 2013 06:14 AM
    Support have said the message is inocuous.
    Explanation Provided:
    • Also that I did a research on these messages & I only see these messages to be more of an internal or background process related message.
    • The same cannot be manually disabled & that we have it fixed in 6.3.X.X.
    All good then.  :smileyhappy:
