Error on access point and controller goes down (Update Required)
  • 1.  Error on access point and controller goes down (Update Required)
    Posted Feb 22, 2017 04:14 AM
    Hello everyone,
    I have a weird problem with one of my access points. When I connect the AP, our local controller goes down (we have 4 controller) and says Update Required.
    Also the AP stays down and I can not provision the AP.
    The following logs are logged:
    Feb 22 10:06:21 sapd[1959]: <311020> <ERRS> |AP xxxxx:aa@10.20xx sapd| An internal system error has occurred at file sapd_cfg.c function send_papi_message_to_ble_daemon line 1660 error Error when sending msg to bd.
    Feb 22 10:06:24 sapd[1959]: sapd_redun_config_dnsmasq, rewrite dnsmasq config file
    Feb 22 10:06:28 sapd[1959]: <311020> <ERRS> |AP xxxxxx@10.20.xx sapd| An internal system error has occurred at file sapd_cfg.c function send_papi_message_to_ble_daemon line 1660 error Error when sending msg to bd.
    Feb 22 10:07:08 sapd[1959]: <311020> <ERRS> |AP xxxxxxxx@10.20xxx sapd| An internal system error has occurred at file sapd_cfg.c function send_papi_message_to_ble_daemon line 1660 error Error when sending msg to bd.
    Feb 22 10:07:10 stm[1787]: trace_rotate_file: rotating /var/log/trace/stm.log
    Feb 22 10:07:10 stm[1787]: trace_on: tracing to "/var/log/trace/stm.log" started
    Feb 22 10:07:18 sapd[1959]: <311020> <ERRS> |AP xxxxxxxx@10.xxxx sapd| An internal system error has occurred at file sapd_cfg.c function send_papi_message_to_ble_daemon line 1660 error Error when sending msg to bd.
    Feb 22 10:07:41 stm[1971]: trace_on: tracing to "/var/log/trace/stm.log" started
    Feb 22 10:07:41 stm[1971]: trace_rotate_file: rotating /var/log/trace/stm.log
    Feb 22 10:07:48 sapd[1959]: <311020> <ERRS> |AP xxxxxxx@10.20.xxxx sapd| An internal system error has occurred at file sapd_cfg.c function send_papi_message_to_ble_daemon line 1660 error Error when sending msg to bd.
    Does anybody have an idea what's wrong?
    Thanks in advance
  • 2.  RE: Error on access point and controller goes down (Update Required)
    MVP EXPERT
    Posted Feb 22, 2017 04:24 AM
    When you say down, what do you mean? Is the controller completely unreachable from the network? Is there any logs on this controller? What kind of topology do you have? (any Master/Master Backup?)
    We'd need more information to progress this but my inital thoughts is that maybe there is an IP conflict? The new AP is using the same IP as the controller and the controller is going offline? I assume you are seeing the Update Required when you run the below on the master?
    #show switches
  • 3.  RE: Error on access point and controller goes down (Update Required)
    Posted Feb 22, 2017 04:41 AM
    Hello, we have a master/standby and 2 local controllers.
    The controller is unreachable for a few moments but stays in the 'down' state. unable to ping at first, then i can ping it but it stays down.
    During this time I cannot connect via ssh.
    this is the command show switches on the master controller
    Many thanks for the idea of a ip conflict. This seems to be the problem.
    We forgot to exclude the controller IP in the dhcp scope!
  • 4.  RE: Error on access point and controller goes down (Update Required)
    MVP EXPERT
    Posted Feb 22, 2017 04:45 AM
    Hey, so all fixed now?
  • 5.  RE: Error on access point and controller goes down (Update Required)
    Posted Feb 22, 2017 04:50 AM
    Yes, much gratitude!
