Error: "perl: warning: Setting locale failed."
  • 1.  Error: "perl: warning: Setting locale failed."
    Posted Feb 21, 2012 05:53 AM
    We recently installed Airwave 7-3-5. Yesterday I logged on to the cli to do an upgrade and noticed this:
    Last login: Mon Feb 20 15:25:40 2012 from XXXXXXX
    perl: warning: Please check that your locale settings:
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LC_CTYPE = "UTF-8",
    LANG = "en_US"
    are supported and installed on your system.
    perl: warning: Falling back to the standard locale ("C").
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LC_CTYPE = "UTF-8",
    LANG = "en_US"
    svn: warning: cannot set LC_CTYPE locale
    svn: warning: environment variable LC_CTYPE is UTF-8
    svn: warning: please check that your locale name is correct
    SVN Root: http://svn.corp.airwave.com/usr/local/svnroot/mercury/tags/RELEASE_7_3_5
    Daemons:
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LC_CTYPE = "UTF-8",
    LANG = "en_US"
    UID PID PPID PGID C STIME TT TIME CMD
    0 4197 1 4197 0 2011 ? 01:29:20 airbus
    0 3990 1 3990 0 2011 ? 00:02:02 httpd_
    0 4193 1 4193 1 2011 ? 20:31:58 Daemon::ServiceWatcher
    0 4199 1 4199 0 2011 ? 00:00:17 Daemon::TupleSpaces
    0 4202 1 4202 0 2011 ? 05:07:42 Daemon::TupleScheduler
    0 4205 1 4205 0 2011 ? 00:01:29 Daemon::SwarmHandler
    0 4222 1 4222 0 2011 ? 00:07:38 Daemon::AlertD
    0 4225 1 4225 0 2011 ? 07:58:50 Daemon::APListCacher
    0 4228 1 4228 0 2011 ? 00:07:03 Daemon::APScanner
    0 4231 1 4231 0 2011 ? 01:02:09 Daemon::APWatcher
    0 4234 1 4234 0 2011 ? 00:00:00 Daemon::APWatcherPollNow
    0 4237 1 4237 4 2011 ? 2-06:22:41 Daemon::AsyncLoggerClient
    0 4244 1 4244 0 2011 ? 00:11:03 Daemon::ConfigPusher
    0 4250 1 4250 0 2011 ? 00:25:52 Daemon::ConfigVerifier
    0 4256 1 4256 0 2011 ? 00:18:49 Daemon::DeviceEvent
    0 4260 1 4260 0 2011 ? 00:17:55 Daemon::DNSFetcher
    0 4282 1 4282 0 2011 ? 00:00:00 Daemon::PartialConfigPusher
    0 4285 1 4285 0 2011 ? 00:00:00 Daemon::PAPI
    0 4327 1 4327 0 2011 ? 04:05:26 Daemon::SNMPEnabler
    0 4329 1 4329 0 2011 ? 00:02:35 Daemon::SNMPFetcher
    0 4340 1 4340 0 2011 ? 05:19:09 Daemon::SNMPV2Fetcher
    0 4342 1 4342 0 2011 ? 00:16:56 Daemon::SNMPV2Fetcher
    0 4346 1 4346 0 2011 ? 03:04:25 Daemon::SyncD
    0 4355 1 4355 0 2011 ? 03:59:14 Daemon::WepKeySetter
    0 4396 1 4396 4 2011 ? 2-06:59:44 Daemon::AsyncLoggerClient
    0 16404 1 16404 0 Feb12 ? 00:32:46 Daemon::PerfCollector
    102 4357 1 4356 10 2011 ? 5-20:26:49 VisualRF
    0 4173 1 4173 0 2011 ? 09:29:35 Daemon::LowLevelServiceWatcher
    0 4208 1 4193 0 2011 ? 00:00:00 msgHandler
    101 4216 1 4216 0 2011 ? 00:00:00 pound
    101 4217 4216 4216 0 2011 ? 00:22:53 pound
    95 4318 1 4318 0 2011 ? 00:02:19 radiusd
    48 3674 1 3674 0 2011 ? 00:16:21 rrdcached
    0 4337 1 4337 0 2011 ? 04:51:10 snmptrapd
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LC_CTYPE = "UTF-8",
    LANG = "en_US"
    Current Version: RELEASE_7_3_5
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LC_CTYPE = "UTF-8",
    LANG = "en_US"
    [root@XXXXXX mercury]#
    Anyone now how I can fix this?
    Mark
  • 2.  RE: Error: "perl: warning: Setting locale failed."
    Posted Feb 21, 2012 10:56 AM
    What is your locale set to?
    This KB article may help you solve the problem:
    http://na2.salesforce.com/_ui/selfservice/pkb/PublicKnowledgeSolution/d?orgId=00D3000000008G4&id=50140000000Mf6j&retURL=%2Fsol%2Fpublic%2Fsolutionbrowser.jsp%3Fsearch%3Dlocale%26cid%3D000000000000000%26orgId%3D00D3000000008G4%26t%3D4&ps=1
    How do I set a local time zone for AWMS / AMP?
    To set a local time zone for AWMS / AMP, use the following command:
    cp /usr/share/zoneinfo/[REGION]/[LOCALE] /etc/localtime
    where [REGION] is one of the directories under /usr/share/zoneinfo/ and [LOCALE] is the desired time zone file under that directory. You will be overwriting the file /etc/localtime with the desired locale file.
    Run the 'date' command to check the results.
    Note that this command merely copies the current file; if the server's time zone changes, the file would need to be copied again. Linking the file via a standard symlink will not work in some circumstances due to a problem with the CPAN 'datetime' module not respecting symbolic links. AirWave is in the process of notifying the CPAN maintainer regarding the symlink problem and will update the datetime CPAN module if and when a new version becomes available.
  • 3.  RE: Error: "perl: warning: Setting locale failed."
    Posted Mar 23, 2012 08:41 AM
    Aruba Techsupport has fixed it. I'm not sure what they did, it wasn't easy it took them a few hours of investigation the issue.
