error role 'authenticated' is unknown
  • 1.  error role 'authenticated' is unknown
    Posted Nov 04, 2014 03:42 PM
    hi there pls i need some help ?
    i have 3 controllers
    ( 1 ) is the master AND  (  2 ) as local and i have this message on all controllers
    so i need some advice
  • 2.  RE: error role 'authenticated' is unknown
    Posted Nov 04, 2014 03:44 PM
    Do all your controllers have at least one PEFNG license installed?
  • 3.  RE: error role 'authenticated' is unknown
    Posted Nov 04, 2014 03:54 PM
    yes there is license  for all controllers ????????????
  • 4.  RE: error role 'authenticated' is unknown
    Posted Nov 04, 2014 03:57 PM
    Did you reload after adding it the first time?
  • 5.  RE: error role 'authenticated' is unknown
    Posted Nov 04, 2014 05:41 PM
    Yes I do
