Error when checking for latest firmware
  • 1.  Error when checking for latest firmware
    Posted May 01, 2018 04:28 PM
    When I perform a check for the latest firmware, I get an error reading: image_check_required class not found.
    Current firmware: 6.5.4.6_63925
    Any ideas what is causing this?
  • 2.  RE: Error when checking for latest firmware
    Posted May 01, 2018 07:07 PM
    when you SSH into the Instant AP and type "show clock" does it have the correct time?
  • 3.  RE: Error when checking for latest firmware
    Posted May 02, 2018 03:03 PM
    Hi, thanks for the reply.  Yes.  It does show the correct time when I type that command.
  • 4.  RE: Error when checking for latest firmware
    Posted May 02, 2018 03:45 PM
    Do you have a screenshot of the error?  Typically checking for updates will not upgrade you any further than what is included in the limited lifetime warranty software here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=20388
  • 5.  RE: Error when checking for latest firmware
    Posted May 02, 2018 03:51 PM
    Here is screenshot.
  • 6.  RE: Error when checking for latest firmware
    Posted May 02, 2018 03:58 PM
    Thank you.
    Is there anything under the upgrade log "show log upgrade" on the Virtual Controller?
  • 7.  RE: Error when checking for latest firmware
    Posted May 02, 2018 04:00 PM
    Not much information:
    main-wap# show log upgrade
    ----------Download log start----------
    download log not available
    ----------Download log end------------
    Download status: incomplete
    ----------Upgrade log start----------
    upgrade log not available
    ----------Upgrade log end------------
    Upgrade status: upgrade status not available
  • 8.  RE: Error when checking for latest firmware
    Posted May 04, 2018 08:58 PM
    Can you please open a TAC case and PM me the case #?
    http://www.arubanetworks.com/support-services/contact-support/
  • 9.  RE: Error when checking for latest firmware
    Posted May 07, 2018 06:10 PM
    I may have figured this out.
    It’s because the 205’s don’t support 8.x code and the cluster is checking in for the latest supported version of code off the cloud, which is 8.3 code.
    The latest version of code for the 205’s is 6.5.4.7 because the memory in the 205’s cannot support 8.x code.
    Can someone confirm?
  • 10.  RE: Error when checking for latest firmware
    Posted May 07, 2018 07:16 PM
    Hi-  How would one confirm this?  And, what is the answer for clusters that contain a 205?
  • 11.  RE: Error when checking for latest firmware
    Posted May 07, 2018 09:51 PM
    6.5.4.3 is the latest that can be obtained by "Check for Firmware".  It should only upgrade you to what is here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/27582/Default.aspx
    If you are on firmware later than that, it should not upgrade automatically past what is on that page.  If you have hardware that requres 8.3, please let TAC know.
  • 12.  RE: Error when checking for latest firmware
    Posted May 07, 2018 10:14 PM
    The Limited Lifetime Warranty info is here:  http://www.arubanetworks.com/assets/faq/FAQ_product_warranty.pdf
    From my understanding, the "check for updates" provides you with the latest software that is shipping with the product.
     With that being said, there is probably an issue with the Check For Updates button that needs to be fixed.
  • 13.  RE: Error when checking for latest firmware
    Posted Jun 30, 2019 10:27 PM
    I have a small cluster with a mix of 303H and 205. The 303H can take 8x code but the 205 can only go up to 6.5x
    Check firmware failes with this error. My understanding is that we need to manually update each one. The GUI expects a URL but the help mentions it can be a local image.
    What URLs do we use? Or does it have to be a local TFTP/HTTP server?
  • 14.  RE: Error when checking for latest firmware
    Posted Jul 11, 2019 02:43 PM
    I have 2 -315 I bought as referb from HP for my house and they are doing the same thing. they are on the 8.x code the DRT updated but the code will not update lol
