Error when upgrading a 650 controller from 6.4.0 to 6.4.2.5
  • 1.  Error when upgrading a 650 controller from 6.4.0 to 6.4.2.5
    Posted Feb 27, 2015 12:15 PM
    Im getting this error
    File copied successfully.
    Saving file to flash:
    Error upgrading image: Image is signed; Basic image verification failed on Ancillary Image
    Anyone konws what it could be or how can it get fixed?
    I read on another tread that it was the checksum but didnt even say how did he fixed it...
    I used that same image on another controller and worked just fine...
    Cheers
    Carlos
  • 2.  RE: Error when upgrading a 650 controller from 6.4.0 to 6.4.2.5
    Posted Feb 27, 2015 03:59 PM
    Well i was already able to solve it myself
    I had on one partition 6.4.2.2 and inthe other 6.4.0
    I tried loading it on 6.4.0 and tried upgrading it with no luck
    i loaded the controller on 6.4.2.2 and didnt work either
    I tried to downgrade it to upgrade it to 6.4.2.4 to see if it works, and i get the same error
    So i tried downgrading it to 6.3.1.14 and it worked
    And then from that i did upgrade to 6.4.2.5 and that worked
    Cheers
    Carlos
  • 3.  RE: Error when upgrading a 650 controller from 6.4.0 to 6.4.2.5
    Posted Feb 28, 2015 07:10 AM
    Hi
    I got the same issue , the probleme is that 6.4 firmware are big to the 650 memory , it is better to keep a partition with an older firmware 6.3 or less in the second partition , and to never update it to 6.4 .
    Regards
  • 4.  RE: Error when upgrading a 650 controller from 6.4.0 to 6.4.2.5
    Posted Feb 28, 2015 05:57 PM
    Well thats weird
    Why i was able to upgrade from 6.4.0 to 6.4.2.2 then?
  • 5.  RE: Error when upgrading a 650 controller from 6.4.0 to 6.4.2.5
    Posted Feb 28, 2015 06:03 PM
    i think that is a space story , because the diffrence between Version 6.3.X.X and 6.4.X.X is more than 10 Mo , and i was getting "space error message"
