Error when using Cloudessa RADIUS server / PEAP
  • 1.  Error when using Cloudessa RADIUS server / PEAP
    Posted Oct 02, 2012 03:28 AM
    I am trying to use external hosted  RADIUS server http://cloudessa.combut I am getting "Error Untrusted Certificate" on the laptop.
    Can Aruba work with external RADIUS servers? I am setting the algorithm to PEAP with MSCHAP2.
    Also  which version of PEAP is good 1.0 or 1.1?
    Thank you,
    Kamatchi
  • 2.  RE: Error when using Cloudessa RADIUS server / PEAP
    Posted Oct 02, 2012 07:38 AM
    You are doing the right thing.
    The Laptop needs to have the Certificate Authoritiy Certificate in the error installed in its Trusted Certificate Authority Store.
  • 3.  RE: Error when using Cloudessa RADIUS server / PEAP
    Posted Oct 06, 2012 06:07 AM
    Hi Joseph.,
    How do I get Certificate Authoritiy Certificate? Can you post a link to it?
    Thank you,
    Kamatchi
  • 4.  RE: Error when using Cloudessa RADIUS server / PEAP
    Posted Oct 06, 2012 08:24 AM
    it looks like on your Windows clients you need to have "Validate Server Certificate" unchecked, according to cloudessa:http://cloudessa.com/faq/
    You would need to have that unchecked for your Windows 7 clients as well.  You would not need a Root CA certificate in that case.
  • 5.  RE: Error when using Cloudessa RADIUS server / PEAP
    Posted Oct 12, 2012 01:02 AM
    Hi Joseph,
    Now it works !!
    Thank you :-)
