Wired Intelligent Edge
Error while installing line card into 6400 switch
  • 1.  Error while installing line card into 6400 switch
    Posted Nov 09, 2022 11:55 AM
    I have problem installing Line Card into 6400 switch. I have double 6400 working in VSX cluster. After inserting line card to one member the line card is initializing, updating and then deinitializing due to VSX config error. Hrere is some logs:
    2022-11-09T13:26:07.689584+01:00 SWITCH hpe-cardd[1363]: Event|3202|LOG_WARN|AMM|1/1|Line module 1/5 removed
    2022-11-09T13:25:43.000829+01:00 SWITCH ops_mgmtintfcfg[6183]: Event|4301|LOG_INFO|AMM|-|MGMT_INTF: Configured admin status up on Mgmt interface
    2022-11-09T13:25:42.959188+01:00 SWITCH hpe-cardd[1363]: Event|3207|LOG_ERR|AMM|1/1|Line module 1/5 has failed: Internal error during VSX configuration
    2022-11-09T13:25:23.118948+01:00 SWITCH systemd-coredump[1609]: Event|1201|LOG_CRIT|LC|1/5|_switchd_agent2 crashed due to signal:6
    2022-11-09T13:23:34.414496+01:00 SWITCH hpe-sysmond[1609]: Event|6303|LOG_INFO|LC|1/5|Current system memory usage for module 1/5 is 26%
    2022-11-09T13:23:06.540372+01:00 SWITCH hpe-cardd[1363]: Event|3221|LOG_DEBUG|AMM|1/1|Line module 1/5 device initialization started
    2022-11-09T13:23:06.540181+01:00 SWITCH hpe-cardd[1363]: Event|3219|LOG_DEBUG|AMM|1/1|Line module 1/5 main power enabled
    2022-11-09T13:23:04.448612+01:00 SWITCH hpe-cardd[1363]: Event|3218|LOG_DEBUG|AMM|1/1|Line module 1/5 enabling main power
    2022-11-09T13:23:04.437038+01:00 SWITCH hpe-cardd[1363]: Event|3211|LOG_INFO|AMM|1/1|Line module 1/5 ISP passed
    2022-11-09T13:22:58.463564+01:00 SWITCH hpe-cardd[1363]: Event|3237|LOG_INFO|AMM|1/1|Line module 1/5 initiating ISP
    2022-11-09T13:22:57.444095+01:00 SWITCH hpe-cardd[1363]: Event|3214|LOG_DEBUG|AMM|1/1|Line module 1/5 has enabled standby power
    2022-11-09T13:22:53.522612+01:00 SWITCH dpsed[1588]: Event|10903|LOG_INFO|AMM|1/1|HA event completed backplane sequence recovery
    2022-11-09T13:22:52.794130+01:00 SWITCH dpsed[1588]: Event|10902|LOG_INFO|AMM|1/1|HA event triggered backplane sequence recovery
    2022-11-09T13:22:47.379223+01:00 SWITCH hpe-cardd[1363]: Event|3203|LOG_INFO|AMM|1/1|Initiating Line module 1/5 reboot
    What can be the cause of this problem? After error switch tries to initialize card again and again.
  • 2.  RE: Error while installing line card into 6400 switch
    Posted Nov 09, 2022 05:33 PM
    Seems like a software or compatibility issue. What is the AOS-CX software version your 6400 running and what is the line card's model/part number?
    Ivan Bondar
  • 3.  RE: Error while installing line card into 6400 switch
    Posted Nov 10, 2022 02:17 AM
    Version : FL.10.07.0020
    Line card: R0X44A
    The same config of line cards is working properly in first node of VSX
  • 4.  RE: Error while installing line card into 6400 switch
    Posted Nov 10, 2022 03:28 AM
    The fact the issue doesn't appear in another VSX peer running the same software doesn't mean it can't be a software issue. Even more, I clearly see indications that it is software issue:
    Crash with signal 6 is seen when a process is terminated with SIGABRT signal due to critical uncorrectable error.
    Of course it may be provoked by a hardware issue, but chances this is a software glitch are much higher. BTW, VSX is not a stack, so configuration-wise both peers are not identical, they may have different configuration (like standalone ports), different states (like IP routing, dynamic peering etc) so again, the fact the LC works in one peer and doesn't in another is not enough to conclude it's not a s/w bug.
    10.07 is not supported from 15-Apr-2022 (you can check end of support dates here - https://www.arubanetworks.com/support-services/end-of-life/ ) I suggest you to upgrade to 10.09.1xxx or better to the 10.10.1xxx which is LSR (long supported release). More information about release types and difference between them you can find here - https://www.arubanetworks.com/support-services/end-of-life/arubaos-software-release/
    Maybe it's a good idea to contact Aruba TAC for deeper investigation, but be prepared for request to upgrade 🙂
    Ivan Bondar
