Error with "backup flash"
  • 1.  Error with "backup flash"
    Posted Feb 23, 2012 11:10 AM
    This is a strange on I ran into on a 3200 controller running AOS 6.1.2.3.
    I'm trying to do a "backup flash" but when I run the command I get the following error:
    (Aruba3200) #backup flash
    Please wait while we tar relevant files from flash...
    Error backing up DBs. May have run out of space
    Here is the files on the flash:
    -rw-r--r--    1 root     root        22200 Feb 23 10:42 20120222-3200Config.cfg
    -rw-r--r--    1 root     root        35708 Feb 23 10:40 20120223-localUserDB
    -rw-r--r--    1 root     root        20558 Nov 10 01:41 default.cfg
    drwxr-xr-x    3 root     root         1024 Nov  7 05:26 fieldCerts
    -rw-r--r--    1 root     root        22282 Feb 23 10:44 original.cfg
    drwx------    2 root     root         1024 Aug 10  2011 tpm
    Any ideas?  I rebooted the controller to no avail.  I wanted to do a backup flash and restore it to another 3200 controller.
    Thank you.
    -Mike
    #3200
  • 2.  RE: Error with "backup flash"
    Posted Feb 23, 2012 11:16 AM
    Do a show storage command.
  • 3.  RE: Error with "backup flash"
    Posted Feb 23, 2012 11:24 AM
    Forgot to include that as well:
    Filesystem                Size      Used Available Use% Mounted on
    none                    300.0M      1.8M    298.2M   1% /tmp
    /dev/hda3               392.7M     74.1M    298.3M  20% /flash
  • 4.  RE: Error with "backup flash"
    Posted Feb 23, 2012 11:31 AM
    How about a show memory?
  • 5.  RE: Error with "backup flash"
    Posted Feb 23, 2012 11:37 AM
    Please open a TAC case.
  • 6.  RE: Error with "backup flash"
    Posted Feb 23, 2012 11:39 AM
    Here is the memory info:
    Memory (Kb): total: 354372, used: 269592, free: 84780
    I also upgraded to 6.1.3.0 and that didn't seem to help.  Oh well. :)  It's an eval controller I'm returning and was looking to get the flash backup to restore.  I'll just manually restore the config and the local userdb.
    Thank you.
    -Mike
  • 7.  RE: Error with "backup flash"
    Posted May 07, 2018 09:42 AM
    Hello friends.
    I hereby ask you for help, if possible.
    I have in my technological park an Aruba controller.
    I'm trying to make a backup with the super user password.
    and I'm having the following problem:
    as the princes say.
    #backup flash
    I have room to perform the procedure, but it is not generating the file
    .tar.gz
    MEMORY:
    Memory (Kb): total: 691936, used: 605532, free: 86404
    STORAGE:
    none 300.0M 21.3M 278.7M 7% /tmp
    /dev/hda3 392.7M 126.0M 246.4M 34% /flash
  • 8.  RE: Error with "backup flash"
    Posted May 07, 2018 09:45 AM
    type "tar crash".
    Then type "dir" to see if any files are taking up lot of space.
