Wired Intelligent Edge
last person joined: 7 hours ago
ERSPAN Aruba Switch
  • 1.  ERSPAN Aruba Switch
    Posted Oct 24, 2019 10:48 AM
    Can Aruba switch be a destination for ERSPAN?
    We want to send ERSPAN traffic from Cisco switch to an Aruba switch, is this posible?
    Andres
  • 2.  RE: ERSPAN Aruba Switch
    Posted Oct 25, 2019 04:34 AM
    Yes, you can. I just created a blog post on the topic!
    AOS - Wireshark: remote capture
    Hhmmm, misread your post. The blog is to send traffic from the switch to a remote Wireshark instance. However, the remote instance can also be a switch. Use the "mirror endpoint" command on the destination switch to capture the traffic and send it to a specific switch port.
  • 3.  RE: ERSPAN Aruba Switch
    Posted Oct 25, 2019 09:38 AM
    Yeah, im looking into having the Aruba switch "receving" ERSPAN
    AP
  • 4.  RE: ERSPAN Aruba Switch
    MVP GURU
    Posted Oct 26, 2019 04:28 PM
    Rene, enhance your blog post with using udpdump from Wireshark (no need to use decode AS) and help for fix issue for some filter... (because include IP on IP encapusulation... )
