ESP connectivity problem on controllers / VMM
  • 1.  ESP connectivity problem on controllers / VMM
    Posted Mar 12, 2018 08:22 AM
    I have a setup with a Mobility Master with two controllers (7010).
    All running AOS 8.2.0.2.
    After a full-setup, the controllers connect to the VMM without any problem, but after a reboot they are not able to create a tunnel with the VMM.
    It is also not possible to create a cluster between the two controllers.
    As far as I can see, the controller refuses connection on the ESP protocol (tested with wireshark).
    Is there an option/feature I could have enabled somewhere in my installation which prevents this connectivity. I've serached for it for hours now, but am not able to find it.
    If needed I could provide a pcap file with traffic to and from my controllers.
  • 2.  RE: ESP connectivity problem on controllers / VMM
    Posted Mar 12, 2018 10:47 AM
    Do you have a backup MM?
  • 3.  RE: ESP connectivity problem on controllers / VMM
    Posted Mar 12, 2018 11:07 AM
    no i don't have a backup vmm
    #AirheadsMobile
  • 4.  RE: ESP connectivity problem on controllers / VMM
    #AirheadsMobile
  • 5.  RE: ESP connectivity problem on controllers / VMM
    Posted Mar 20, 2018 03:55 AM
    In a "show acl hits" I see the following. Could that be the problem?
    sdn-acl any any 58 34816-34816 ofaction 12 1658 1658 9260 ipv6
    sdn-acl any any 58 34560-34560 ofaction 24 1688 1688 9261 ipv6
    sdn-acl any any any ofaction 23 17326 17326 9262 ipv4
    sdn-acl any any 6 5223-5223 ofaction 19 51 51 9269 ipv4
    sdn-acl any any 17 0-65535 ofaction 22 1 1 9276 ipv4
    sdn-acl any any 17 0-65535 ofaction 11 3081 3081 9284 ipv4
    sdn-acl any any any ofaction 1 163217 163217 9286 ipv4
  • 6.  RE: ESP connectivity problem on controllers / VMM
    Posted Jun 10, 2019 04:10 PM
    Have you found resolution regarding your issue and explanation on the action: "ofaction?"
