Ethernet Frames.
  • 1.  Ethernet Frames.
    Posted Nov 04, 2014 05:13 AM
    What is the exact difference between 802.11 and 802.3 Ethernet frames??
  • 2.  RE: Ethernet Frames.
    Posted Nov 04, 2014 05:39 AM
    Each share similar fields but have different size and the amount of address fields required for transmission
    - 802.3 only requires source and destination addresses
    - 802.11 can use up to 4 addresses
    - 802.3 max size is 1500 bytes
    - 802.11 max size is 2300 bytes
  • 3.  RE: Ethernet Frames.
    Posted Nov 04, 2014 06:42 AM
    Which types of address are these 4 address ?
  • 4.  RE: Ethernet Frames.
    Posted Nov 04, 2014 06:46 AM
  • 5.  RE: Ethernet Frames.
    Posted Nov 04, 2014 07:01 AM
    Thank you both.
