last person joined: 7 hours ago
Ethernet setting on IAP 205
  • 1.  Ethernet setting on IAP 205
    Posted Mar 28, 2018 10:25 PM
    My first post here & my first work with Aruba wireless :)
    Is there any way to force the speed on an aruba 205 access point's ethernet interface to 100/full. A cisco switch that it connects to is showing lot of errors.
    The switch side was already tried changing to auto/hard coded.
    Thanks in advance.
    Ethernet Duplex/Speed Settings
    Autoneg Speed (Mbps) Duplex Iface
    on 100 Full bond0
    ArubaOS (MODEL: 205), Version 6.4.3.1-4.2.0.0
  • 2.  RE: Ethernet setting on IAP 205
    Posted Mar 29, 2018 01:31 AM
    Hi
    I understand that you have mobility controler. check this profile:
    Configuration --> AP Group --> <AP-Group of the desired AP> -> AP -> Ethernet interface 0 port configuration --> Ethernet interface link profile
    Regards
    Piotr Filip
  • 3.  RE: Ethernet setting on IAP 205
    Posted Mar 29, 2018 02:01 AM
    I think this is more of an IAP acting as the controller.
    Please let me know. Thanks.
  • 4.  RE: Ethernet setting on IAP 205
    Posted Apr 01, 2018 12:11 PM
    Goto "MORE > WIRED"
    Select ETH0 profile and edit
    Set Speed
    ** it will applied to ALL Access Point !!
    -Yopianus Linga-
  • 5.  RE: Ethernet setting on IAP 205
    Posted Apr 03, 2018 12:55 AM
    Thanks, but our IAP does not show that option under wired.
    It just has fields till admin status.
    any other options that i can try please?
  • 6.  RE: Ethernet setting on IAP 205
    Posted Apr 03, 2018 12:57 AM
    some screenshot would be helpful.
    -Yopianus Linga-
  • 7.  RE: Ethernet setting on IAP 205
    Posted Apr 03, 2018 01:00 AM
    Make sure you click SHOW ADVANCED setting, or you can try using CLI
    IAP-Set Port
    -Yopianus Linga-
  • 8.  RE: Ethernet setting on IAP 205
    Posted Apr 08, 2018 09:01 PM
    Thanks much. i got it finally.
    Just another query , an IAP-275 is currently acting as the IAP controller role. However, there was another IAP acting as controller earlier, but it seems to be flapping on/off. Is there any way to look in the GUI of IAP to see the flaps & its reason to understand the role changes.
  • 9.  RE: Ethernet setting on IAP 205
    Posted Apr 08, 2018 09:06 PM
    I think you should check on the switch logs for that. The main reason IAP changes master/role ussualy because the previous master is down.
    Try changing the cable or port of the troubled IAP.
    -Yopianus Linga-
