Ethernet uplink not active yet
  • 1.  Ethernet uplink not active yet
    Posted Nov 26, 2012 04:08 PM
    I'm trying to setup an AP-135 but the ENET0 port doesn't want to light up. Below is the boot up sequence.
    APBoot 1.2.6.7 (build 30025)
    Built: 2011-08-30 at 17:41:16
    Model: AP-13x
    CPU:   88F6560 A0 (DDR3)
    Clock: CPU 1600MHz, L2 533MHz, SysClock 533MHz, TClock 200MHz
    DRAM:  256MB
    POST1: mem 0 mem 1 mem 2 mem 3 passed
    Flash: 16 MB
    Power: 802.3af POE
    LAN:   done
    PHY:   ....done
    PEX 0: RC, link up, x1
           bus.dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00.00   00  11ab  6560 00005   02 f1000000 00000000 00000000 00000000
           00.01   00  168c  0030 00002   01 90000000 00000000 00000000 00000000
    PEX 1: RC, link up, x1
           01.00   00  11ab  6500 00005   02 f1000000 00000000 00000000 00000000
           01.01   00  168c  0030 00002   01 94000000 00000000 00000000 00000000
    Net:   eth0, eth1
    Radio: ar9390#0, ar9390#1
    Hit <Enter> to stop autoboot:  2  1  0
    Booting OS partition 0
    Checking image @ 0xf8100000
    Copying image from 0xf8100000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ## Booting image at 02000200 ...
    Uncompressing... done
    Aruba Networks
    ArubaOS Version 6.1.3.4-3.1.0.1 (build 35899 / label #35899)
    Built by p4build@cyprus on 2012-10-26 at 18:24:45 PDT (gcc version 4.3.3)
    Memory: 256MB = 256MB total
    Memory: 243456KB available (2564K code, 8868K data, 4708K init, 0K highmem)
    Delay calibration in progress:
    Calibrating delay loop... 1593.34 BogoMIPS (lpj=1593344)
    PEX0 interface detected Link X1
    PEX1 interface detected Link X1
    wdt: registered with refresh
    Enabling Watchdog
    i2c /dev entries driver
    i2c-arran: using default base 0xf1018100
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    Ethernet port 1 mode: tunnel
    Ethernet Channel Bonding Driver: v3.5.0 (November 4, 2008)
    eth0: link down
    ADDRCONF(NETDEV_UP): eth0: link is not ready
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    eth0: link down
    bonding: bond0: enslaving eth0 as a backup interface with a down link.
    eth1: link down
    ADDRCONF(NETDEV_UP): eth1: link is not ready
    wifi uplink not present...
    No uplink active. Becoming Mesh Point
    AP xml model 51, num_radios 2 (jiffies 19126)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 16
    radio 1: band 0 ant 0 max_ssid 16
    election init: rand=14 HZ=500
    ethernet_device_event: dev eth0 is register
    ethernet_device_event: dev eth0 is up
    ethernet_device_event: dev eth1 is register
    setting bond0 as bridge child
    setting gre0 as split child
    Starting watchdog process...
    Starting Webserver
    bind: Transport endpoint is not connected
    Launching NTP Client on 64.90.182.55
    ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_spectrum: Version 2.0.0
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_ahb: 0.9.4.5 (Atheros/multi-bss)
    ath_ahb: No devices found, driver not installed.
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    Shutting down eth1 due to insufficient POE voltage [power profile 2]
    wifi0: Base BSSID 6c:f3:7f:a3:f4:70, 16 available BSSID(s)
    eth0 address=6c:f3:7f:c2:3f:46
    br0 address=6c:f3:7f:c2:3f:46
    wifi0: AP type AP-135, radio 0, max_bssids 16
    wifi0: Atheros 9380: mem=0xf3000000, irq=25 hw_base=0xd3380000
    wifi1: Base BSSID 6c:f3:7f:a3:f4:60, 16 available BSSID(s)
    wifi1: AP type AP-135, radio 1, max_bssids 16
    wifi1: Atheros 9380: mem=0xf4000000, irq=24 hw_base=0xd33c0000
    Starting FIPS KAT ... Completed FIPS KAT
    shutting down watchdog process (nanny will restart it)...
    	<<<<<       Welcome to the Access Point     >>>>>
    process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
    !!!tag vlan all on eth1
    vap aruba000 vlan is 0. fwd-mode:0 mesh
    eth1: link down
    ethernet_device_event: dev eth1 is up
    vap aruba001 vlan is 0. fwd-mode:0 mesh
    User: POE power conditions have improved: the new condition would be 'POE: No restrictions'
     Any ideas?
  • 2.  RE: Ethernet uplink not active yet
    Posted Nov 28, 2012 10:21 PM
    Am I able to change the speed of ENET0 from the console? I believe it is set to auto and this is what is causing the issue.
