Eval license
  • 1.  Eval license
    Posted Dec 18, 2014 06:07 AM
    iam tring to create Eval license for aruba controller 3200
    i used EVL-2048-AP as i didn't find any thing else and after activate license i get this and i can't add at the controller also i need LIC-PEFNG-1 and i can't find it
    Certificate ID: 1zKoFaul-kVQK0k2g-vuFtdB/a-wSMxb5n0
    Part Number: EVL-2048-AP
    Part Description: Access Point License (2048 AP Evaluation License)
    System Serial Number/MAC: BG0028963
    System Part Number: 3200XM
    System Part Description: ARUBA 3200XM (0 AP SUPPORT)
    Activation Key: f2P3XgCm-EbS8zBi8-ClXUKJJy-C6aRQxIZ-djZ4Czed-AwY
  • 2.  RE: Eval license
    Posted Dec 18, 2014 07:02 AM
    What version of code are you running?
  • 3.  RE: Eval license
    Posted Dec 18, 2014 09:27 AM
    i tried again with cli command and it work now
    thanks alot for your response
  • 4.  RE: Eval license
    Posted Jan 02, 2015 05:02 PM
    hi Ess Lam ,
    confirm that you are using a pre-version 5.0 version of ArubaOS because this licence works with version 6.0 and later.
    confrim that you are using the correct Controller S/N.
    confirm that you  have copy the the activation kay without any space
  • 5.  RE: Eval license
    Posted Jan 02, 2015 05:03 PM
    hi Ess Lam ,
