I used to generate an evaluation license from LMS, now i couldn't able to see generate evaluation license option in LMS. is it moved to somewere else? or how can i generate it?
It should be under "Certificate Management". If you cannot see options to Create or Generate licenses please contact support to get it fixed or clarified.
Thanks Joseph!
i dont see that option under "certificate management" but i used to generate before!
anyway i will crack it from support! thanks
Hi
I am facing the same problem. Do you contact support?
Regards
I recently experiended the same issue and after contacting TAC it was resolved.
After contacting TAC , 10 min issue was solved.
Nice:)
