Developer
Everything in global PoE example
  • 1.  Everything in global PoE example
    Posted Jul 17, 2019 10:18 AM
    Very rough, everything in global, PoE on/off and port status to screen.
    This video demos the process:
    import requests
    import urllib3
    import pprint
    urllib3.disable_warnings(urllib3.exceptions.InsecureRequestWarning)
    ip_addr = "192.168.50.29"
    creds = {"userName": "admin", "password": "admin123"}
    login = requests.post(
    "http://{}/rest/v4/login-sessions".format(ip_addr),
    json=creds,
    verify=False,
    timeout=10,
    cookie = {"cookie": login.json()["cookie"]}
    if login.status_code == 201:
    print("Login OK to ArubaOS-Switch")
    else:
    print("Login error to ArubaOS-Switch IP: {}".format(login.status_code))
    # turn_on_poe = requests.put(
    # "http://{}/rest/v4/ports/10/poe".format(ip_addr),
    # json = {'is_poe_enabled': True},
    # headers=cookie,
    # verify=False,
    # timeout=10,
    turn_off_poe = requests.put(
    json={"is_poe_enabled": False},
    headers=cookie,
    verify=False,
    timeout=10,
    poe = requests.get(
    "http://{}/rest/v4/poe/ports".format(ip_addr),
    headers=cookie,
    verify=False,
    timeout=10,
    single_port = requests.get(
    headers=cookie,
    verify=False,
    timeout=10,
    pprint.pprint(single_port.json())
    logout = requests.delete(
    headers=cookie,
    verify=False,
    timeout=10,
    print(logout.status_code)
