Excessive down APs
  • 1.  Excessive down APs
    Posted Jun 07, 2013 04:42 PM
    After updating to 7.6.4 my campuses and buildings in VisualRF show "excessive down APs" even though that's not the case. Restarting AMP and rebooting the system didn't help. Any ideas?
  • 2.  RE: Excessive down APs
    Posted Jun 07, 2013 04:47 PM
    Are there any errors in the /var/log/visualrf/visualrf.log or visualrf_msg.log?
  • 3.  RE: Excessive down APs
    Posted Jun 07, 2013 04:58 PM
    Both log files show a lot of errors like this one:
    2013-06-07 13:45:22,160 ERROR AirBusMs[1]  com.airwave.model.external.SubscriptionMessageTask AP ID[192] discovered by Type[com.airwave.model.AccessPointRadio] Key[79.2] has no matching Radio at 5.0GHz
  • 4.  RE: Excessive down APs
    Posted Jun 07, 2013 05:05 PM
    This may be an issue with the catalog repository.  What make / model of AP is at  id 192?
    You can get to the device quickly by doing:
    http://your.amp.name.here/ap_monitoring?id=192
    Also, please open a support case as this will require both support and development interaction to arrive at a fix.
  • 5.  RE: Excessive down APs
    Posted Jun 07, 2013 05:12 PM
    Id 192 is an AP61. I'll open a support case as you suggested.
    Thanks for your quick replies!
  • 6.  RE: Excessive down APs
    Posted Jun 18, 2013 12:11 PM
    Update from Aruba tech support:
    The defect is in open state and Dev team is working on this now.
