Excessive undersized/giant packets. error on HP devices
This thread has been viewed 318 times
  • 1.  Excessive undersized/giant packets. error on HP devices
    Posted Jul 23, 2015 11:26 AM
    Hi
    I have HP 2610 and 2530 POE switches to which I connect my aps (AP 135, AP 105, AP 205).
    Looking at the logs i see a lot of the following messages regarding the ports to which aps are connected:
    W 07/23/15 15:32:47 00327 FFI: port 4-Excessive undersized/giant packets. See help.
    W 07/23/15 15:32:27 00327 FFI: port 3-Excessive undersized/giant packets. See help.
    The MTU size is set to "" in SAP MTU, so it should be set automatically.
    Why I got those messages?
    What can I do?
    #AP205
  • 2.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Jul 23, 2015 11:27 AM
  • 3.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Jul 23, 2015 11:53 AM
    Yes, I had read the article, but didn't read the link posted below
    http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Oversize-jumbo-frame-errors/m-p/5421/highlight/true#M1860
    so setting the MTU size to 1500 is in this case a best practice, did I understood it correctly?
  • 4.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Jul 23, 2015 12:05 PM
    Yes, if you set the AP MTU to 1500, it should solve the problem.
    Massimo
  • 5.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Feb 04, 2021 02:55 PM
    This is a little dated.  Is this still relevant with 8.x code?  I am seeing the same thing here on an HPE/Aruba switch with an Aruba AP attached to it.
    Jim Lucas
  • 6.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Feb 04, 2021 03:29 PM
    Yes.
  • 7.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Feb 05, 2021 09:52 AM
    Colin,
    I cannot access some of the articles linked from above.  Is this a problem or just an annoyance?  If nothing is broken, should I be concerned?
    Jim
    Jim Lucas
  • 8.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Feb 05, 2021 01:23 PM
    That link was before the forum was migrated.  The tl;dr is to set the MTU in the AP system profile to 1500 to stop the "giants".
  • 9.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Aug 10, 2022 04:05 AM
    Hi.
    I cannot find any MTU settings in Aruba central? (Checked under Access point (tab) -> config -> System (tab) and wish "show advanced").
    Could you please provide a screenshot or a more exact description of where/how this setting is accessed/modified?
    (funny thing is I'm 99.9% sure I've seen MTU during setups lots of times so I'm wondering if it's been removed in newer versions of central)
  • 10.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Aug 10, 2022 04:26 AM
    Unless you are tunneling traffic from an access point to a controller, this thread doesn't apply to Central-Based Instant access points.
  • 11.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Aug 10, 2022 05:09 AM
    Thank you for the quick answer.
    I see, but how then do I get rid of the "Excessive undersized/giant packets" warning (that also turn my overview map red as if switches are down 🙄) for certain switch ports that are connected to Aruba AP:s?
  • 12.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Aug 30, 2022 04:46 PM
    Actually it does - managing IAPs and switches in Central applies as switch default MTU sizes are 1500 and IAP default MTU sizes are 1300. Executing a CLI command of "mtu 1500" will not change the SAP/RAP MTU sizes of your br0 bridge and it will not remedy your "Excessive undersized/giant packets" alerts.
    Unfortunately I have not yet found the fix-action.
  • 13.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Jan 05, 2023 10:32 AM
    Hi all.
    I have an Aruba Central version 10.x solution (Yes version 10 so Cloud Managed devices, no instant)
    with SSID tunnelling traffic from APs (AP-5xx so 11ax) and the GW.
    The wired network is not Central managed
    How should I set the MTU ?
    Should I set the MTU on APs and GW or on the switches ?
  • 14.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Jan 05, 2023 06:02 PM
    you can't set MTU on AP that run AOS10 as they'll dynamically learn it . So it will be on switch and gateway
  • 15.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Jan 10, 2023 03:04 AM
    So,
    how should I configure the switch ports were APs are connected to ?
    Can you link me to the specific documentation
    Thank you
  • 16.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Jan 10, 2023 04:08 AM
    Try to set the jumbo statement to all VLANs associated to those ports.
    Example:
    vlan 1
       name "DEFAULT_VLAN"
       no untagged 1-6,8-9
       untagged 7,10
       no ip address
       jumbo
       exit
    vlan 2
       name "Home_Wired"
       untagged 8-9
       no ip address
       jumbo
       exit
    sw00# show vlans
     Status and Counters - VLAN Information
      Maximum VLANs to support : 256
      Primary VLAN : DEFAULT_VLAN
      Management VLAN : Management
      VLAN ID Name                             | Status     Voice Jumbo
      1       DEFAULT_VLAN                     | Port-based No    Yes
      2       Home_Wired                       | Port-based No    Yes​
  • 17.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Jan 10, 2023 08:52 AM
    Thank you Herman,
    I'll do the test and upgrade the post with the result
    Thank you for now
  • 18.  RE: Excessive undersized/giant packets. error on HP devices
    Posted Jan 12, 2023 04:53 AM
    In my experience setting jumbo frames on vlan did solve the issue in my setup. It's unfortunate for procurve switches to have this limitation in FW but solution is straight forward and at least for my setup is working just fine.
    The "problem" is in the process how APs are probing MTU size and procurve switches does not like it and log event when AP is trying bigger packets.
    Best, Gorazd
    Gorazd Kikelj
    Selectium Adriatics d.o.o.
