Wired Intelligent Edge
Exchange VSF Member 24P to 48P
  • 1.  Exchange VSF Member 24P to 48P
    Posted Jan 16, 2019 03:41 AM
    we have a 4-member Stack with three 48P and one 24P switches. We now want to exchange the 24P with a 48P. All switches are from the 2930f series and using 16.07. as software.
    We shutdownd the 24P and tried to provison it anew with a new type, but it failed:
    nsrc584test(config)# vsf member 4 type JL558a
    This will save the current configuration. Continue (y/n)?  y
    The switch type does not match the configured switch type for this memberId.
    Then i had read in the Best Practice guide, that i would need to remove the old VSF Links, but this failed again:
    nsrc584test(config)# no vsf member 4 link 2 4/28
    Standby or Member is missing, therefore the command
    cannot be executed.
    Is there anything i am missing? Thanks!
  • 2.  RE: Exchange VSF Member 24P to 48P
    Posted Jan 16, 2019 01:06 PM
    Greetings!
    I apologize for the confusion; this was an inadvertent oversight in the stacking/VSF member replacement procedure. When replacing a stack or VSF member with a different model, the original member must be removed from the configuration prior to adding the replacement, and any member-specific configuration (interface settings, VLAN assignments) must be re-applied to the configuration after adding the replacement.
    The document has been updated and re-uploaded to my original post with the corrected procedure.
