Exclude range in Instant DHCP
  • 1.  Exclude range in Instant DHCP
    Posted Mar 26, 2014 04:57 PM
    Is it possible to exclude an IP range of 172.31.99.180 and above from the Instant default DHCP Pool
  • 2.  RE: Exclude range in Instant DHCP
    Posted Mar 26, 2014 04:58 PM
    From playing around with an IAP, there does seem to be a way around it, but it seems a bit odd to do it this way.
    1. Click on System--Show Advanced Options and click on DHCP.
    • Select a different range than what is the default 172.31.98.0/23
    2. Click on More--DHCP Server
    • Add an "Other" scope and select the type “Local”
    • Choose a VLAN for this scope
    • Use the 172.31.98.0/23 subnet
    • Exclude 172.31.99.180 (everything above this IP will be excluded)
    • Fill in the other fields as needed
    3. Change the SSIDs to be statically set to this VLAN
    • Edit the SSID and change it from "Virtual Controller Assigned" to "Network Assigned"
    • Select a Static VLAN, and use the VLAN number created for the scope in step 2
