existing cert on the same name or path
  • 1.  existing cert on the same name or path
    Posted Jul 17, 2019 05:06 AM
    i tried to upload certificates on my new controller 7205... but i got msg ""similar name certificate already exists on the same or different path , upload with a different name"" ,, but i didn't upload any cert. before so i dont know how its exist ?? need help urgently . thanks
  • 2.  RE: existing cert on the same name or path
    Posted Jul 18, 2019 04:40 AM
    If you need urgent help, please contact Aruba Support.
    Without information like the firmware version that you use, how you try to upload the certificate, what is the history, it is just guessing what might be the issue. What you may try is to simplify the name of the file that you upload, so if the filename is: controller-cert.my-subdomain.my-domain.com July 2019.pem, try to change it to someting like controller19.pem and try again.
