Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
Existing switches to Aruba Central
  • 1.  Existing switches to Aruba Central
    Posted Jan 23, 2023 11:22 AM
    Hi Everyone,
    I am very new to Aruba central, is there a way to migrate existing switches to the portal without wiping out the existing configuration?
    Also, if you have better links on how to import switches to AC. That would be very helpful.
    Thank you
  • 2.  RE: Existing switches to Aruba Central
    Posted Jan 23, 2023 05:00 PM
    yes you can. Check this link for provisioning CX switches
    https://www.arubanetworks.com/techdocs/central/latest/content/nms/aos-cx/get-started/quick-start-switch-cx.htm
    and this one for AOS-S switches.
    https://www.arubanetworks.com/techdocs/central/latest/content/nms/aos-switch/get-started/quick_start_switch.htm
  • 3.  RE: Existing switches to Aruba Central
    Posted Jan 23, 2023 06:41 PM
    Thanks for the info, would you know how long it usually takes to add a switch in Aruba Central?
  • 4.  RE: Existing switches to Aruba Central
    Posted Jan 23, 2023 07:01 PM
    it should not take long. Also note that with Aruba Central subscription, you have 24x7 access to Aruba TAC.
