Expand Reach of AP93
  • 1.  Expand Reach of AP93
    Posted May 26, 2015 06:23 AM
    A customer wants to expand the reach of their AP93.
    What can i do ?
    I would like to order a new AP205 but can the AP93 support roaming with this device couse the need the same firmware.
    I cannot find the right firmware for the AP93.
    What can I do best ?
    regards
    Taco
  • 2.  RE: Expand Reach of AP93
    Posted May 26, 2015 06:49 AM
    There is firmware for the AP93 that matches the AP205.  Support should be able to get that for you or PM me and I will get you the matching firmware.
  • 3.  RE: Expand Reach of AP93
    Posted May 26, 2015 07:26 AM
    How can I send you a PM ?
  • 4.  RE: Expand Reach of AP93
    Posted May 26, 2015 07:46 AM
    Click on my name and click on "Send this user a private Message"
  • 5.  RE: Expand Reach of AP93
    Posted May 26, 2015 07:12 AM
    yes we can create a cluster with IAP 93  and IAP 205 but note, when we add IAP 93 cluster size will be restricted to only 16.
    You need to download Orion code for IAP 93 and same version of Taurus code for IAp 205.
    Hope you got solution, please feel free for any further help on this.
    For your ref :
