Expiring and multiple password for one SSID
  • 1.  Expiring and multiple password for one SSID
    Posted Aug 13, 2018 03:02 PM
    Hi, just want to ask if it's possible to have multiple password for a single SSID ? I also wanted them to expire in a specific period of time.
    Can you hand me some steps? I am using Aruba Instant. I find it hard to configure some settings.
    Thanks!
  • 2.  RE: Expiring and multiple password for one SSID
    Posted Aug 13, 2018 03:04 PM
    Pre-Shared Keys or guest accounts?
  • 3.  RE: Expiring and multiple password for one SSID
    Posted Aug 13, 2018 03:08 PM
    What do you mean by Pre Shared Keys?
    All SSIDs are employee-type.
  • 4.  RE: Expiring and multiple password for one SSID
    Posted Aug 13, 2018 03:20 PM
    Sorry but I don’t understand your question.
  • 5.  RE: Expiring and multiple password for one SSID
    Posted Aug 13, 2018 03:26 PM
    I mean, the SSID that I want to have the multiple and expiring password is set for Employees.
  • 6.  RE: Expiring and multiple password for one SSID
    Posted Aug 13, 2018 03:28 PM
    Yes, the user accounts would be configured in your identity store.
  • 7.  RE: Expiring and multiple password for one SSID
    Posted Aug 13, 2018 03:35 PM
    I want to set a different password for some sort of people, how can I possibly do that? Thanks!
  • 8.  RE: Expiring and multiple password for one SSID
    Posted Aug 13, 2018 03:36 PM
    In your identity store.
  • 9.  RE: Expiring and multiple password for one SSID
    Posted Aug 13, 2018 06:06 PM
    Can you tell me where I can find it? I use Aruba Instant
  • 10.  RE: Expiring and multiple password for one SSID
    Posted Aug 13, 2018 06:09 PM
    You would need an external user identify store to expire the user accounts. Typically, this would be done in something like Active Directory, or your guest provisioning system. Instant itself does not provide this functionality on its own.
  • 11.  RE: Expiring and multiple password for one SSID
    Posted Aug 13, 2018 06:10 PM
    What is your identity store?
