Expiring Radius Certificate
  • 1.  Expiring Radius Certificate
    Posted Apr 23, 2014 12:21 PM
    What needs to be done on Aruba controllers to upgrade an expiring certificate on a radius server?
  • 2.  RE: Expiring Radius Certificate
    Posted Apr 23, 2014 12:26 PM
    Nothing needs to be changed on the controller if you are terminating EAP on your RADIUS server.
  • 3.  RE: Expiring Radius Certificate
    Posted Apr 23, 2014 06:50 PM
    Are you doing EAP termination on the controllers? If yes. Please ensure that you have the most current code. Second option is to submit a CSR from the controller and get a new cert install on the controller. Please also ensure to update the aaa profile with the right cert.
    If you are not doing EAP termination on controller and using a CA SERVER in your AD forest with the RADIUS server that does 802.1x auth then I would suggest you to submit a new CSR from the RADIUS server and generate a new certificate from CA SERVER and load it as an authentication certificate on your AAA/RADIUS server.
    Thank you.
