Export list of clients on a SSID
Jump to Best Answer
This thread has been viewed 22 times
  • 1.  Export list of clients on a SSID
    Posted May 26, 2022 07:05 AM
    I'm failing to find a way of exporting a filtered list of (or any list) of clients on a SSID. This was simple using Cisco Prime in our previous wireless infrastructure, but I can't find a way for it in Glass or on the Mobility Conductor (I'd prefer it straight off the Conductor). I just want that list of 503 MAC addresses.
    nathan millward
  • 2.  RE: Export list of clients on a SSID
    Posted May 26, 2022 07:35 AM
    Do you have Airwave?
  • 3.  RE: Export list of clients on a SSID
    Posted May 26, 2022 07:59 AM
    There are 3 Airwaves. think it ended up like that because each AW can only handle 4000 APs. So our default is to look at Glass for info.
    nathan millward
  • 4.  RE: Export list of clients on a SSID
    Posted May 26, 2022 09:13 AM
    I don't think that the controller supports exporting lists of clients from the gui.  You have the option of, on the commandline of typing "no paging" and then "show user" to get the data you want.
  • 5.  RE: Export list of clients on a SSID
    Posted May 26, 2022 09:48 AM
    Thanks Colin. Sounds like what I wanted to do, and what was so easy with the competition (!)  is a proper chore with Aruba. Looks like I have to do that across 13 controllers then.  I best stop trying to find another way and just get on with the "show user" output.
    Cheers
    ----edit---- it's 10 controllers now, we're up to mc13, but the oldest 3 have been removed from service.
    nathan millward
  • 6.  RE: Export list of clients on a SSID
    Posted May 26, 2022 09:54 AM
    If you only have 3 Airwave servers, they all support exporting of user lists through the GUI.
  • 7.  RE: Export list of clients on a SSID
    Posted May 26, 2022 10:12 AM
    Was hoping to do it from Glass. But doesn't seem to be an option.
    From the AW servers an export of all clients in all folders got me MACs, but not the WLAN they were on.
    Ultimately your steer on the cli 'show user'  worked best as i added 'essid <name>' and then copied the output to Excel.
    nathan millward
  • 8.  RE: Export list of clients on a SSID
    MVP
    Posted May 26, 2022 10:25 AM
    You can export the client list in AMP and have it include SSID (and various other details; lots of options). You just need to edit the "view" and choose the columns you want. Then you can easily export your csv.
    So for example go to Clients->Connected, either edit the current view or create a new one, and select the columns you want. Then export.
    Cody Ensanian
