Network Management
Export Visual RF maps WITH APs displayed?
  • 1.  Export Visual RF maps WITH APs displayed?
    Posted Dec 23, 2016 10:09 AM
    Browsing the forum... don't see a way to do this:
    Can Airwave output PDF or even JPG/PNG of floorplans that include access points?
    Like so:
    Currently I'm using screenshots, but I'd like to get be able to get something with higher resolution/quality, if possible.
  • 2.  RE: Export Visual RF maps WITH APs displayed?
    Posted Dec 26, 2016 08:56 AM
    You can try the below,
    • Go to Visualrf
    • Click on the list view for the maps
    • You would see download map option towards right
    Vishnu
  • 3.  RE: Export Visual RF maps WITH APs displayed?
    Posted Jan 10, 2017 12:52 PM
    Sorry Vishnu, I'm asking for a map WITH APs displayed. Almost as if one were to create a PDF/PNG/ some file type of what is seen in Visual RF (without having to log in, click to the campus, building, floor).
    I have been doing screenshots, but I assumed there must be a better approach?
  • 4.  RE: Export Visual RF maps WITH APs displayed?
    Posted Jan 23, 2017 10:35 AM
    Try this:
    For an individual floor:
    From the view that shows the building as a stack of floors (drill down into campus, then drill down into the building)
    Right click on a floor -> bill of materials, uncheck all options -> ok
    The output should be a word doc with the raw floor showing AP placement.
    You can also do this from the campus view to get an entire building, or even from the network view to get the entire campus.
  • 5.  RE: Export Visual RF maps WITH APs displayed?
    Posted Jan 24, 2017 06:28 AM
    Works for me. Good info, Rob.
  • 6.  RE: Export Visual RF maps WITH APs displayed?
    Posted Jan 31, 2017 12:58 PM
    Rob,
    Thanks for the suggestion... unfortunately, I don't get any graphic, just a table listing AP info.
    Like so:
  • 7.  RE: Export Visual RF maps WITH APs displayed?
    Posted Jan 31, 2017 03:17 PM
    The word doc export should have a floor plan prior to the AP inventory table.
    Mine returns:
    If you're still not seing the floor plan like so, then please open a support case and a support engineer can help debug.
  • 8.  RE: Export Visual RF maps WITH APs displayed?
    Posted Jan 31, 2017 03:23 PM
    Thanks, will do
  • 9.  RE: Export Visual RF maps WITH APs displayed?
    Posted Mar 07, 2017 12:34 PM
    "Create case" option seems to be futzed:
  • 10.  RE: Export Visual RF maps WITH APs displayed?
    Posted Mar 07, 2017 12:37 PM
    Thanks for the heads up.  We recently migrated into the HPE tracking system, so things may have broken during the move.  Will get the admins to take a look into it.
  • 11.  RE: Export Visual RF maps WITH APs displayed?
    Posted Mar 22, 2017 01:35 PM
    OK, I just tried again (to create a case)... no go. Same bug, webform looks wacky.
    Could I get someone to create a case for me, in the meantime?
    I'd really like to print out my building maps (without doing screenshots)
  • 12.  RE: Export Visual RF maps WITH APs displayed?
    Posted Mar 22, 2017 01:40 PM
    @the.sleeper: I've pinged support to open a support case for you.
  • 13.  RE: Export Visual RF maps WITH APs displayed?
    Posted Apr 07, 2017 09:38 AM
    Rob/everyone,
    OK, I finally got my issue cleared up (needed to delete a VRF cache)
    Here's a sample map of what I get when I do the BOM:
    I didn't realize at first that the APs were included--that's how small they are.
    But if you zoom in, they are there:
    So, its close, but is there any way to increase the size of the AP icon?
    (I tried tweaking the size in VisualRF, but that didn't seem to have an effect.)
  • 14.  RE: Export Visual RF maps WITH APs displayed?
    Posted Apr 08, 2017 06:41 AM
    Currently we do not have option in Airwave to increase the AP size in BOM report, I would recommand to file feature request.
    Pavan
  • 15.  RE: Export Visual RF maps WITH APs displayed?
    Posted Apr 12, 2017 12:06 PM
    Thanks Pavan, could you point me to where to do that?
    (btw, I'm still not able to create cases from threads)
  • 16.  RE: Export Visual RF maps WITH APs displayed?
    Posted Apr 12, 2017 12:20 PM
    You could login to support.arubanetworks.com site and go to contact suupport section and click on Access Feature Requests via Idea Portal
  • 17.  RE: Export Visual RF maps WITH APs displayed?
    Posted Apr 12, 2017 12:45 PM
