Exporting Clearpass Guest Accounts to another Clearpass instance
  • 1.  Exporting Clearpass Guest Accounts to another Clearpass instance
    Posted Mar 28, 2015 12:14 PM
    All,
    I'm working with a customer right now and we are migrating a good number of Clearpass Guest accounts from a 6.3 to a new 6.5 cluster. I exported the guest accounts in an XML format and imported them into 6.5. The problem is that the passwords appear to be reset on all of the accounts.
    I setup a Clearpass 6.3, 6.4 and 6.5 instance this morning to see if I could get to the bottom of this. The first thing that I did was to enable the Show Guest Password button under Guest Manager. The exported XML file now contained the correct passwords from Clearpass 6.3. I tried to import this into 6.4 and 6.5 and the passwords were still reset on the accounts.
    Has anyone found a solution to this problem? Thanks for the help!
    -Mike
  • 2.  RE: Exporting Clearpass Guest Accounts to another Clearpass instance
    Posted Mar 28, 2015 01:34 PM
    Try the following :
    Imported using the .csv format and then it should give you the option to whether you want it use a random password or to keep the field as is
  • 3.  RE: Exporting Clearpass Guest Accounts to another Clearpass instance
    Posted Mar 30, 2015 06:01 PM
    Victor,
    This was spot on! Thank you for your time in putting together those screencaps.
    -Mike
