I'm having a hard time understanding something with procurve and applying extended ACL's to VLANS. I'm applying them with the direction IN which I thought meant the ACL is applied to all packets coming IN to the VLAN. What I'm noticing though is I have to reverse the Source/Destination on the ACL.
Example:
ip access-list extended "CUST-Access-IN"
502 deny ip 10.1.0.0 0.0.255.255 172.17.0.0 0.0.255.255 log
503 deny ip 172.17.0.0 0.0.255.255 172.17.0.0 0.0.255.255 log
600 remark "==== Allow All ==="
601 permit ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255 log
exit
vlan 2010
name "VLAN2010"
tagged F1-F2,F4,K1-K4,L1-L4,Trk50
ip address 172.17.12.254 255.255.255.0
ip access-group "CUST-Access-IN" in
exit
Now VLAN 10 doesn't have any ACL. So when I try to communicate from VLAN 2010 (172.17.12.4) to VLAN 10 (10.1.0.2) it works just fine. Even though you can see the deny from SOURCE 10.1.0.0/16 to 172.17.0.0/16.
So if I change it around:
502 deny ip 172.17.0.0 0.0.255.255 10.1.0.0 0.0.255.255 log
exit
Then it finally blocked it when I telnet from 172.17.12.4 to 10.1.0.2 on port 88.
How come the source/destination is REVERSED in my mind?? If you look at wireshark you can see the Source/Destination and the ports. Yes, 172.17.0.0 should be able to hit 10.1.0.2 on port 88 but the traffic coming back shouldn't be allow in this example. It goes From 60214(random) -> 88 and then comes back 88 -> 60214 which should be blocked
#VLAN#ACL#ExtendedACL#5400
