extended SSID
  • 1.  extended SSID
    Posted Jun 19, 2015 07:23 AM
  • 2.  RE: extended SSID
    Posted Jun 19, 2015 09:19 AM
    Can you please add more details to what you are trying achieve ?
  • 3.  RE: extended SSID
    Posted Jun 21, 2015 07:05 AM
    Hi friend,
    Are talking about the default config of the extended SSID ? in the new code, by default extended SSID will be enabled for restricting mesh functionality.
    please feel free if you are looking for something else.
  • 4.  RE: extended SSID
    Posted Jun 21, 2015 02:34 PM
    Dear Friends
    I have already implemented 15 days back Extendd SSID feature on IAP103 with default OS 6.4.xxx loaded on that.
    I just added IAP103 in Virtual Group and just disabled Extended SSID option, and then placed IAP103 at desired location in Mesh and it worked.
    But now I am trying same thing for IAP215, It doesn't work. Updaed OS also to 6.4.2.6-4.1.1.7_50209 from 6.4.2.0-4.1.1.0_45444.
    Arvind Rajan
    Spire Infotech
  • 5.  RE: extended SSID
    Posted Jun 22, 2015 07:40 AM
    Unless something has changed recently, i do not believe Mesh is supported yet on the 200 series of APs.
    _ELiasz
  • 6.  RE: extended SSID
    Posted Jun 22, 2015 08:14 AM
    Hi friend,
    Aruba 11ac APs do not supported mesh, can expect this soon.
