Extended SSID can't be disabled - bug? AP-207
  • 1.  Extended SSID can't be disabled - bug? AP-207
    Posted Mar 30, 2020 07:19 AM
    Observed with AP-207, the AP has been converted to 'standalone mode':
    - When disabling Extended SSID (via Configure -> System -> Show Advanced Options -> General), save and then reboot, the Extended SSID option is still activated.
    - When doing the same via CLI (conf t -> no extended-ssid -> end -> save & reboot) it doesn't stick either but is active once again after reboot.
    Therefore WiFi uplink doesn't work (show wifi-uplink status shows 'Extendssid enable!')
    Any ideas? Am I missing something? OS 8.6.0.3
  • 2.  RE: Extended SSID can't be disabled - bug? AP-207
    Posted Mar 30, 2020 07:46 AM
    On CLI you where missing the "commit apply" to get it in the running config.
  • 3.  RE: Extended SSID can't be disabled - bug? AP-207
    Posted Mar 30, 2020 08:42 AM
    @jAyR, thanks I did that, even though I didn't write it in my post above...
  • 4.  RE: Extended SSID can't be disabled - bug? AP-207
    Posted Nov 12, 2020 02:54 AM
    I had the same problem, the issue is; you probably still had the default setmeup SSID in the configuration.
    I disabled the ESSID (ignore the reboot warning), created a new SSID and then rebooted all APs. That way the ESSID stayed disabled
    Dave
