External (3° party) CP with iAP cluster
  • 1.  External (3° party) CP with iAP cluster
    Posted Apr 26, 2017 09:22 AM
    Hi Airheads!
    I have a customer that ask me to give to his clients a WiFi guest network with a captive portal in order to track accesses and collect data.
    Ok, no problem, but he wants to use his Landing Page service (instapage) to create the splash page and collect data.
    The AP are iAP-204, so, no controller in use.
    The good thing is that he doesn't care about authentication, he asks the customers to fill a little form (Name, Surname, Gender, Mail) and then the registration is done, so I don't need an authentication server (Radius) in order to manage the authentication/authorization of the guests.
    How can I do the trick? How can I tell to the iAP cluster VC that a specific user (device) has completed the form and is now authenticated, and so change the role from pre-auth to authenticated?
    Thanx a lot for support!
  • 2.  RE: External (3° party) CP with iAP cluster
    Posted Apr 26, 2017 10:23 AM
  • 3.  RE: External (3° party) CP with iAP cluster
    Posted Apr 26, 2017 10:30 AM
    GREAT! Thanx a lot!
    Gianluca Galleani - Sistec S.r.l.
    IT Engineer
    Mail: ggalleani@sistec.net
    Skype: metalgalle
    Teamviewer QuickSupport: https://get.teamviewer.com/rw6pa5h
    Tel: +39 031 396312 (ext. 101)
    Fax: 031565433
    Contattami con Kite
    ________________________________
    Hai bisogno di assistenza tecnica?
    Registrati ed accedi al portale helpdesk.sistec.net oppure invia una mail a helpdesk@sistec.net
    Per l'assistenza remota, utilizza Teamviewer scaricandolo dal seguente indirizzo: https://get.teamviewer.com/rw6pa5h
    Questo messaggio e' stato analizzato da Libra ESVA ed e' risultato non infetto.
    This message was scanned by Libra ESVA and is believed to be clean.
    Per informazioni: http://helpdesk.sistec.net
  • 4.  RE: External (3° party) CP with iAP cluster
    Posted Apr 26, 2017 11:53 AM
    Ok, I manage to do that this configuration works, but now I have a problem: once I have correctly authenticated a client, all other clients connecting to that SSID, get the authenticated role without having to land to the captive portal.
    In fact, at the time of the connection, they does not get the pre-auth role...
    Also forcing to logout the clients with the iAP GUI does not make the pre-auth works again...
  • 5.  RE: External (3° party) CP with iAP cluster
    Posted Apr 27, 2017 04:01 AM
    Found the problem, i wrongly put the auth text in the landing page.
    Unfortunately there is no way to make the solution works because I need to make that users stick to the preauth unless they complete the landing page form.
    If I put the auth keyword in the form redirect page, it seems that the iAP does not read it, or does not care about it!
    Obviously, I checked that the source code of the HTML result page contains the auth Keyword!
    Strange thing is that if I use CPPM (instead using my Bitnami-LAMPstack test VM) to create the landing page, WITHOUT any type of authentication (no RAIDUS, no MAC, ...), just asking for Name and Mail, and simply put the auth keywork in the receipt page (also without caring about username and password), IT WORKS like a charm!
    I'm baffled.... :-S  :-(
  • 6.  RE: External (3° party) CP with iAP cluster
    Posted Apr 27, 2017 04:04 AM
    Can you paste some of your config related to this?
  • 7.  RE: External (3° party) CP with iAP cluster
    Posted Apr 27, 2017 05:14 AM
    Sure! :-)
    iAP conf:
    version 6.4.4.0-4.2.4
    virtual-controller-country IT
    virtual-controller-key c6a47e6001b71caca369bfbb2a528823ea5d7f57dc933f7849
    name instant-CD:19:64
    terminal-access
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap 94:b4:0f:cd:19:64
    arm
     wide-bands 5ghz
     80mhz-support
     min-tx-power 18
     max-tx-power 127
     band-steering-mode prefer-5ghz
     air-time-fairness-mode fair-access
     client-aware
     scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    mgmt-user admin 592361be961b7c1034ce0042a644321c
    wlan access-rule instant
     index 0
     rule masterip 0.0.0.0 match tcp 80 80 permit
     rule masterip 0.0.0.0 match tcp 4343 4343 permit
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
    wlan access-rule default_wired_port_profile
     index 1
     rule any any match any any any permit
    wlan access-rule wired-instant
     index 2
    wlan access-rule CP-Test
     index 3
    wlan access-rule CP-Test_Preauth
     index 4
     rule 10.1.100.165 255.255.255.255 match any any any permit
     rule any any match any any any deny
    wlan ssid-profile CP-Test
     enable
     index 0
     type guest
     essid CP-Test
     opmode opensystem
     max-authentication-failures 0
     vlan guest
     set-role-pre-auth CP-Test_Preauth
     rf-band all
     captive-portal external profile CP
     dtim-period 1
     broadcast-filter arp
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
    auth-survivability cache-time-out 24
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "AUTHZ"
     auto-whitelist-disable
     https
    wlan external-captive-portal CP
     server 10.1.100.165
     port 80
     url "/guest.php"
     auth-text "AUTHZ"
     redirect-url "http://www.youporn.com"
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
     wireless-containment none
    wired-port-profile wired-instant
     switchport-mode access
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-instant
     speed auto
     duplex auto
     no poe
     type guest
     captive-portal disable
     no dot1x
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     disable
    airgroupservice airplay
     disable
     description AirPlay
    airgroupservice airprint
     disable
     description AirPrint
    Landing page code:
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=8"/>
    <?php
    if ($_POST['E-mail']!=""){
    echo "<meta http-equiv='refresh' content='3;url=http://10.1.100.165/guest_ok.php'>";
    <html>
    <head>
    <title>Compila il form per poter accedere alla rete</title>
    </head>
    <body>
    <h2>Inserisci i dati</h2>
    <form action="guest.php" method="post" accept-charset="UTF-8" enctype="application/x-www-form-urlencoded" novalidate="novalidate">
    Nome: <input type="text" id="Nome" value=""><br>
    Cognome: <input type="text" id="Cognome" value=""><br>
    E-Mail: <input type="text" id="E-mail" name="E-mail" value=""><br>
    <?php
    echo $_POST['E-mail'];
    echo "<input type=hidden value='AUTHZ'>
    "; } ?> <input type="submit" id="Login" value="Accedi"><br> </form> </body> </html>
    Here you can find that there are a hidden form field that is displayed only if the POST returns the E-Mail field as not-empty.
    And also, if the e-mail field is returned as not-empty, I force a redirect to another blank page that have "AUTHZ" keyword in the Title tag.
  • 8.  RE: External (3° party) CP with iAP cluster
    Posted Apr 27, 2017 05:45 AM
    Nice redirect for authenticated clients ;)
  • 9.  RE: External (3° party) CP with iAP cluster
    Posted Apr 27, 2017 05:49 AM
    :-D :-D :-D :-D :-D :-D
    We need some fun also @lab! ;-)
