Thanks for the tip - is it possible to set these values AFTER provisioning, and without Provisioning Rules?
I also cannot see how to check the current gain values on the APs. I did some searches and found a CLI command - but I don't have CLI access to this controller.
Is there a default gain applied (if the user doesn't set one)?
In my case, customer set the EIRP to 27dBm (5 GHz radio) and I have no idea what the configured gain is - I assume if the default configured gain is 0 dBi and the EIRP is configured as 27 dBm, then the radio will try to produce 27 dBm of power - which is very high in certain UNII bands.
For APs with internal antennae, I assume all of this is taken care of by the controller - i.e. if I want max EIRP of 18 dBm, then the AP knows how much power to crank out of that radio to achieve the EIRP. Is that right?
Arne Bier
Original Message:
Sent: Mar 01, 2021 03:13 AM
Subject: External Antenna Gain Configuration for AOS Controller Based - How?
Hi Arne,
you can set Provisioning Rules for AP Model, IP-Range, Network Address or any AP to automatic apply Antenna Gain to that AP. This is done by the "Provisioning Rule" which you find on the "Managed Network" Level - Configuration - Access Points - Provisioning Rules
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/0a49fe8264bf441d8b93ca42c5ef24e1.png)
Another possibility is doing it manually while provisioning process of the dedicated AP.
Original Message:
Sent: Feb 28, 2021 08:14 PM
Hello
With a MM/MC controller solution running 8.5.0.5, how do I set the gain of the externally attached antennas?
We use the AP374
regards
Arne
Arne Bier
