I have recently installed the below APs to one of our office. I am facing few issue and would require help in resolving the same. 1. Client are not getting speed greater then 54Mbps even though some of client are supporting the 802.11ac. 2. The signal strength of clients connected to respective APs is showing very low3. I am receiving the error that external Antenna needs configuration for most of the APs
I am using one of the AP as virtual controller for Mgmt. purpose.Below are part code for APs and antenna which are used. Total Number of APs at the site : 9 Part Number : IAP-204-RW Antenna Part Number : AP-ANT-1W Please let me know if you require any other information.
Niren
Thanks for your quick reply.
What is input I need to put under gain? Is it depends of Antenna type or AP?
Can I use 4 and 6 for 2.5Ghz and 5Ghz respectively?
I am using the WPA & WPA2 Enterprise for Encryption.
Encryption type is TKIP and AES both. Is the speed depends to encryption type which was configured on client wireless profile?
Yes,
TKIP does not allow you to connect at more than 54.
