External captive portal
  • 1.  External captive portal
    Posted Feb 22, 2016 11:19 PM
     Does external splash page  and external authentication in guest caseof IAP are always meant for clearpass or i can use any third party captive portal or my own built captiveportal and authentication  .
  • 2.  RE: External captive portal
    Posted Feb 22, 2016 11:21 PM
    Anything can be used...
    Sent from Nine
  • 3.  RE: External captive portal
    Posted Feb 23, 2016 12:22 AM
    can  you tell me  how can i add logo of my company  in my internal  Captive portal ?
  • 4.  RE: External captive portal
  • 5.  RE: External captive portal
    Posted Feb 23, 2016 01:30 AM
    Can you tell me  how  INTERNAL  captive  portal  appears when user  logins ... i can  not find  its image  or apperance  on internet as   most of the  images and videos  are showing  captive portal  during  configuration  due to  which  i am  not getting an  idea about its final  apperance  ...currently  i dont  have  physical  IAP ...i know  how  clear pass  captive  portal appear i am interested in only  IAP's captive  portal
  • 6.  RE: External captive portal
    Posted Feb 23, 2016 03:55 AM
    There is a preview button so you an see what it looks like.
  • 7.  RE: External captive portal
    Posted Feb 23, 2016 04:13 AM
    can you  please  share a snap  shot  after  taking  preview as i dont  have  physical unit  .
    Thank you
    Regards
    Kashan
  • 8.  RE: External captive portal
    Posted Feb 23, 2016 04:17 AM
    Here you go.  Suffice to say it's pretty basic.
