External Captive Portal
  • 1.  External Captive Portal
    Posted Oct 20, 2016 05:56 PM
    Ok so I had a test IAP 215 from Aruba for testing before purchase. I setup Radius and my own captive portal for guest access. Everything was working great so before giving back the demo I backed up the config.
    Purchased new IAP 315 restored the config from the test device and that loaded the config great. But now I cannot login through the captive portal and it seems to have to do with this line in the index file  <form method=POST action="http://securelogin.arubanetworks.com/cgi-bin/login"> with this it will just spin and spin till i get a webpage not available. FYI once someone logs in it takes them to my companies .edu page. If I change it to this  <form method=POST action="https://securelogin.arubanetworks.com/cgi-bin/login"> it will ask to add the certificate and I can login fine. But I didn't need that https in the previous config.
    Any help with this would be great thanks
    Alex
  • 2.  RE: External Captive Portal
    Posted Oct 20, 2016 05:58 PM
    Did you upload your captive portal certificate?
  • 3.  RE: External Captive Portal
    Posted Oct 20, 2016 05:59 PM
    I did not upload a captive portal cert. I did not know I had to as it worked fine previously with the test device.
    thanks
  • 4.  RE: External Captive Portal
    Posted Oct 20, 2016 06:14 PM
    How do I upload this cert? Is this becase when restoring from the previous device it is using that Cert?
    thanks
  • 5.  RE: External Captive Portal
    Posted Oct 20, 2016 06:17 PM
    The cert previously included was not designed to be used in production environments. Please take a look here:
    https://community.arubanetworks.com/t5/Controller-less-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Instant/ta-p/275814
