Why not use Cloud Guest in that case?
This question is answered in this thread, which is Instant but same concept as AOS10 in bridge mode.
Original Message:
Sent: Jul 15, 2024 06:08 AM
Subject: External Captive Portal Configuration
Hello dear,
Well, we use Aruba Central bridge mode and the OS is AOS10
Original Message:
Sent: Jul 15, 2024 02:48 AM
What type of equipment do you have? Aruba? Other brands? If Aruba, is it controller based AOS8, or Instant AOS8, or AOS10, bridged, tunneled?
Original Message:
Sent: Jul 13, 2024 04:12 AM
Hi there,
I would like to to use an external captive portal hosted on external web server. The external captive portal contains the terms and condition. A user should agree on them then they grant access.
Now the configuration is done and the user is enforced to redirect to the external captive portal but I struggle with the authentication process. I just need the authentication URL with the parameters to integrate into the external web page.
Can someone please help me out?
KARWAN
